AX-15 Bell Housing - JeepForum.com
post #1 of 17 Old 07-31-2005, 03:28 PM Thread Starter
Jeep_YJ
Jeep_YJ's Avatar
AX-15 Bell Housing
Does anyone know where i can get a bell housing for a 94 YJ?? I've looked all over and cannot find one. I cracked mine when my u-bolt straps broke and the drive shaft went around. It bent the output shaft from the transfercase and then cracked my bell housing from the starter around the top.
Thanks,
Josh
Jeep_YJ is offline
post #2 of 17 Old 07-31-2005, 03:55 PM
$300WRANGLER
Ive got one that came off a 93. Not sure if they are the same or not but if your interested let me know.
1993 Red Jeep Wrangler 4.0L HO 200K Miles runs strong AX-15 Tranny WAS BROKE NOW FIXED Perfect body/interior JUST WRONG COLOR
For 300 bucks couldn't go wrong!! First Project : Tranny
Second Project: Let the modding begin
$300WRANGLER is offline
post #3 of 17 Old 07-31-2005, 04:24 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The '93 has the internal clutch slave cyl, '94 has the external.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 17 Old 07-31-2005, 04:31 PM Thread Starter
Jeep_YJ
Jeep_YJ's Avatar
yes mine has the external slave cyclinder. thanks thought this has not been a fun time trying to find this bell housing. If anyone has any other ideas on where i might find one let me know
Thanks,
Josh
Jeep_YJ is offline
post #5 of 17 Old 07-31-2005, 05:02 PM
emyselfandi
why just a 94 bell housing? why not look for a 94-99 bell housing? my ax15 is from a 98 and it all bolts up fine. i'd post on the wanted section of your local and some national boards. YOu will find one quick if you post for a bunch of years. I used to see them go on ebay for cheap every once and a while. T
emyselfandi is offline
post #6 of 17 Old 07-31-2005, 05:15 PM
lostboy
Hey ...check out the 93. It could work as the casting is probably the same. You just have to move over the fork pivot from yours.
I put a 94 in my 89 that had the peugeot and it looked exactly the same.The old one even had the mounting for the cps sensor.
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #7 of 17 Old 07-31-2005, 05:47 PM
JeeperDon
JeeperDon's Avatar
The castings are different. One has bolt bosses for the inside slave and the other for an outside slave. Stick with finding a '94/'95 bell housing.
Web Admin for
post #8 of 17 Old 07-31-2005, 08:12 PM
JOKER4INK
Check www.car-parts.com They have bell housings for your application if someone here doesnt.
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline
post #9 of 17 Old 07-31-2005, 08:29 PM Thread Starter
Jeep_YJ
Jeep_YJ's Avatar
Thanks for that website!!
Jeep_YJ is offline
post #10 of 17 Old 07-31-2005, 09:52 PM
91GTA350
I had the problem of finding one when I was dong my ax15 conversion. Call up a place called "Wabash Auto". Its a salvage yard in Wabash Indiana. They had one for me sitting on their shelf and they shipped it same day so that was nice. I lost their phone number but just go to yellowpages.com and you will find it.
steve
-89 sahara 258: HAD a peugot and a d35
5/15/05 - took ownership and started money pit
9/17/05 - found a 3.5' deep water hole
2/18/06 - destroyed spiders in d35
4.2/AX-15/NP-231/SYE/30/8.8/3.55/RE 2.5"/31"
91GTA350 is offline
post #11 of 17 Old 05-12-2015, 10:24 AM
lakelotman2
Me too having trouble finding an bellhousing to fit AX 15 to 4.0
Any idea where to find the bellhousing? need 95 or up with AX15 for external slave swap
Thanks,
Josh
lakelotman2 is offline
post #12 of 17 Old 05-12-2015, 01:01 PM
glenn-91YJ
glenn-91YJ's Avatar
Look for an XJ with an external slave setup. I just grabbed a complete 96 XJ AX15 for $180! All I wanted was the bell housing, seal housing and fork to have when the time comes for a clutch/slave replacement. A lot more XJs available.
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #13 of 17 Old 05-13-2015, 11:16 PM
Opihi59
from here it gets rough
Opihi59's Avatar
You can find these on ebay very frequently. You need any Jeep 94 or newer AX 15 bellhousing (well, don't get one that was right hand drive), and you can also look for NV3550 Jeep bellhousing which will fit on the AX15 without modification. Whatever you find first, and/or cheapest.
If you get an AX 15 bellhousing 93 or older, it is set up for Internal clutch slave and will not work for an external clutch slave setup.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #14 of 17 Old 05-14-2015, 11:35 AM
JMAC90YJ
JMAC90YJ's Avatar
Davys Jeeps in Ohio sells them
http://daveysjeeps.com/specials.html
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN THEY'RE PUSHED DOWN THE STAIRS.
JMAC90YJ is offline
post #15 of 17 Old 05-14-2015, 12:48 PM
Partsmke
I have one that came off a 1998 TJ. It is sitting in my garage and I would sell it for $100. I hope this is a legal post, I've been banned from the TJ forum for what they called trolling, something I didn't do as it "is a person who sows discord on the Internet by starting arguments or upsetting people, by posting inflammatory, extraneous, or off-topic messages in an online community (such as a newsgroup, forum, chat room, or blog) with the deliberate intent of provoking readers", I never tried to provoke anyone ...
Partsmke is offline
2.5L uprgrade to 4.0L - bell housing? turf-pro YJ Wrangler Technical Forum 9 03-12-2009 03:00 PM
bell housing question yj_beater51 YJ Wrangler Technical Forum 21 02-18-2009 10:41 PM
Bell Housing Plate? ahewy YJ Wrangler Technical Forum 1 06-27-2007 06:06 PM
bell housing ? NOTQUITEMUSASHI YJ Wrangler Technical Forum 2 01-09-2006 02:49 PM
AX-15 Bell Housing on a BA-10/5? boulderz YJ Wrangler Technical Forum 4 03-12-2005 09:31 AM
