AW4 Overflowing -- Too full? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > AW4 Overflowing -- Too full?
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 03-22-2012, 09:01 PM   #1
mrmonkey
I just did a 2.5L/AX5 to 4.0/AW4 swap and still working through some problems. I think the biggest problem is the tranny. I wondered if at first it was too full because after the engine heated up and I was heavy on the throttle the ATF would start to leak out between the two pieces of the dipstick tube. Every time I checked the ATF level it seemed plenty full and I was worried it was too full so I decided to drain it this week. I pulled the plug and drained the pan and put in about 3 quarts (just to be safe). Took it for a drive and came back once it was warm to check the level again and it read full even with 3 quarts.
I'm not sure if the ATF isn't cooling enough, if there is an oil resevoir that is clogged or if it is just too full. What do you guys think?
mrmonkey is offline   Reply With Quote
