Avg MPG for your YJ - Page 3 - JeepForum.com
post #31 of 39 Old 03-08-2013, 07:00 AM
blown50
1987 YJ Wrangler
17-23 mpg, stock 3:07, BA 10, 30x9:50 toyo, hard top with AC, 4.7 Stroker, Weber 32/36.
blown50 is offline
post #32 of 39 Old 03-08-2013, 08:23 AM
rodgers3
Man you know somethings wrong when a stroker is getting better mileage than you.
rodgers3 is offline
post #33 of 39 Old 03-08-2013, 09:05 AM
Wranglin4Life
I have a 93 w/ 2.5L and I see between 17-22 depending on how I drive and how bad the winds are. I drive it to work about 1-2 times a week. Its stock except for a little bit bigger tires.
Wranglin4Life is offline
post #34 of 39 Old 03-09-2013, 02:22 PM
sptrmike
sptrmike's Avatar
18-21 mixed city highway, 4.2 ,2150, msd, nuttered. 3:73 on 32 procomp at's.
sptrmike is offline
post #35 of 39 Old 03-09-2013, 02:25 PM
rubinscube
11mpg tire and rack on top "nutterfied" 1988
rubinscube is offline
post #36 of 39 Old 03-11-2013, 05:03 PM
pasinbuy
Not really, if done right a stroker will get better mileage. That is only if you drive it normal and do not use the power.
Built motors are typically more efficient with the ported, polished heads and etc. that goes with the built motor. But again you loose the efficiency when you use the power.
pasinbuy is offline
post #37 of 39 Old 03-11-2013, 06:10 PM
rodgers3
Hmm well thanks for that bit of info!
Im still learning here
rodgers3 is offline
post #38 of 39 Old 03-11-2013, 06:23 PM
MukYJ
MukYJ's Avatar
14-16 with the old 2.5, 5 speed, 31" tires, and stock 4.11 gears.
I'm curious to see if the new 2.5 gets better mileage.
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline
post #39 of 39 Old 03-11-2013, 06:24 PM
polishdevil
Originally Posted by ben944
I avg. 17 mpg. Running 31/10.5/15's with 2.5L & automatic trans.
You give me hope. My 94 has the 2.5 auto 3.73s with 31's and I'm getting 10-11 mpg. I've done a complete tuneup including all the fluids. All I have left is the oxygen sensor and the thermostat with rad flush.
polishdevil is offline
gas , gas mileage , mileage , mpg
