Avg MPG for your YJ - Page 2 - JeepForum.com
post #16 of 39 Old 03-07-2013, 06:23 AM
caoboy
Last I checked was 14.7. Mostly city. I've changed an O2 sensor since then, and am tuning it up. I'll report back when I fill up again. Might be a while, I don't daily my Jeep (yet).
2.5/31's/5spd/4.10's
caoboy is offline
post #17 of 39 Old 03-07-2013, 08:22 AM
pete1991YJ
Originally Posted by zombiechief View Post
I'm getting about 12 with a 2.5 5sp and 4:10's on 32" Cooper Discoverys. I would LOVE to get 20 out of my squirrels.....
Sounds like its time for some tune-up work. That made all the difference in the world on mine. Especially all the vacuum lines and various small leaks. Plus the fact that my PO really took care of it. He wheeled it, but he also maintained it. I got all the reciepts and record from him.
Getting 20 is pretty good, they were rated for that when they were brand-new.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #18 of 39 Old 03-07-2013, 08:44 AM
zombiechief
About the only thing I have not replaced is the o2 sensor. I did all the vacuum lines and a full tune up on it when I got it. The previous owner had it sitting up for about 8 years. Before they parked it it was a tow behind for their RV.
Treat every situation like a dog. If you can't eat it or play with it pee on it and walk away.
zombiechief is offline
post #19 of 39 Old 03-07-2013, 08:51 AM
Chrisnvegas
Chrisnvegas's Avatar
8-18 mpg. @8 mpg at the dunes. Ran through 3 tanks of fuel. But I was on it all the time in deep sand climbing huge dunes. It gets up to 18 on the hwy if I keep the speed around 55-60. It drops like a rock as I near 70, and at 75+ forget it.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #20 of 39 Old 03-07-2013, 09:03 AM
joey48442
I've been getting 18-19 pretty consistently. That's according to my gps, not the trip odometer, which shows 3percent low. Mine is 1993 2.5 5 speed with 225/75 hankook winter ipikes, which are incredible in the snow, but I imagine heavy and sticky which hurts mileage. I hope to hit 20 in the summer.
Joey
joey48442 is offline
post #21 of 39 Old 03-07-2013, 09:39 AM
pete1991YJ
And yet the O2 sensor is the #1 thing that determines your fuel mileage, after gears and tires.
post #22 of 39 Old 03-07-2013, 10:02 AM
jamesbland123
1987 YJ Wrangler
So you guys getting over 15 with larger tires did you regear your speedo? I'm getting 14 mpg on a 4.2 MPFI that's been recently tuned including new injectors, new tank, plugs, etc... I'm happy with the results but I just don't see how people are getting close to 20 mpg if gearing and numbers are correct.
Then again I'm in CA and if I took off the cat, ran a simple breather, and got rid of the charcoal canister I may be able to get a few more miles out of it.
jamesbland123 is offline
post #23 of 39 Old 03-07-2013, 10:27 AM
pete1991YJ
Actually the smog stuff doesn't make much difference to the MPG's. I'm in NY and we have smog inspection now too, in addition to the mech/safety.
My speedo isn't changed, but it it was I would get even more. The thing is, I have the 2.5 MPFI, its smaller, and I drive like a granny cuz it doesn't have any power. I never go over 55 or 60, and I never pass anyone. The limit is 65 anyhow, so who cares? I never give more than 1/2 throttle. I keep it *extremely* tuned up and tight. The bigger tires helps with the MPG's also because the give an effectively higher gear.
post #24 of 39 Old 03-07-2013, 10:35 AM
The1AndOnlyBug
I use my GPS to find out how far I've driven.
My Vehicles
'89 Wrangler 4.2 .....Sold......
'08 Grand Prix GXP 5.3 V8 303 hp 323 ft-lb tq, my baby =D ..... SOLD.......
'94 wrangler 4.0, parted out/traded off
'94 Wrangler 4.0 K&N cold air, bored throttle body, head polished, Comp cam, 4.5" RE extreme duty, ubolt flip, 1" booms, 1" daystar body, M.O.R.E shock mount extenders rear, shock mount extenders on front, D35 W/ Richmond Lunchbox, 4.56 Gears, 35/12.5/15 Pro Comp M/T, Black D steelies, Front bumper W/ Stinger and winchplate (Armorology), Warn XD9000I, Dakota seats,Kenwood KDC-MP342U head unit, Soundbar with Kicker DS65's, Kicker DX200.4 Amp, Kenwood 6X9 on bottom of rollbar, Infinity 4X6's in dash, Tuffy Glovebox, 4 100W Daylighters, and a CJ hardtop.
2012 HD Night Rod Vivid black stock =D
R.I.P. Chad Daniel French 29 July 1982 - 25 Oct 2010 I'll Miss you Bro
The1AndOnlyBug is offline
post #25 of 39 Old 03-07-2013, 11:02 AM
Ripper3494
Yep my speedo is correct, I actually use the mpg reading directly from my pcm
Probably sent from under my broken heep
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #26 of 39 Old 03-07-2013, 09:20 PM
imstillatwork
2.5l
235,000 miles
33x12.5 @ 22lbs
4.88 gears
12-14MPG
imstillatwork is offline
post #27 of 39 Old 03-08-2013, 04:34 AM
Old4X
1990 CJ7
4.2
Nuttered
BBD
235 tires
18 city, 22 highway
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #28 of 39 Old 03-08-2013, 04:48 AM
grizzlycb
I drive a 92 2.5 5speed. Standard gearing with soft top 31x10.5 mud tires. Full size spare and a smitty built stinger. Last time I checked I got 11-12 on high way and closer to 15 in the city. I also have a hole in my header and hole in muffler. (Luckily my new headers came in yesterday and my muffler will be here tomarrow) I just assumed there is no such thing as good gas mileage in a jeep though. There's no fun in good gas mileage. Lol
grizzlycb is offline
post #29 of 39 Old 03-08-2013, 04:54 AM
superj
9-11 mpg
4.5 with a four barrel and needing a tune up while running almost 32s (worn out)
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #30 of 39 Old 03-08-2013, 05:53 AM
rodgers3
This^^^
I check mine every now and then just to see what its getting.
rodgers3 is offline
gas , gas mileage , mileage , mpg
