Average cost to replace a clutch - JeepForum.com
post #1 of 27 Old 07-25-2007, 06:05 AM Thread Starter
tj7695
Ok, so I bought my Wrangler about 3 weeks ago, and already I think the clutch needs to be replaced. Reason is, I have noticed over the past few days the friction point has gotten progressively lower to the floor, and this morning, it was really hard to shift into any gear (1st especially), as if the clutch isn't fully engaged. What should I expect as an average cost to replace the clutch?
tj7695 is offline
post #2 of 27 Old 07-25-2007, 06:18 AM
JGBrown
1995 XJ Cherokee
Have you tried bleeding the fluid?
Mine sucked right after I bought it, I bled it and filled it to the right level and it has been well behaved since as far as pressure goes but it didn't change the shifting much.
I also switched the fluid in the transmission since it was quite low, I think most of the shifting problems came from that since it has been smooth shifting and reliable since.
as far as cost, I was quoted 400$+parts to do mine from the cheapest, 1340$ including parts from the most expensive.
'88 yj, Rancho 5k shocks, add-a-leafs , 1.5" shackle lift.
2.5L TBI, 29" tires on CR offset wheels, extended brake lines and swaybar Homebrew(useless) cold air intake.
SOLD
Current:'95 Cherokee, almost stock.
JGBrown is offline
post #3 of 27 Old 07-25-2007, 06:38 AM
Axl Jack
Replaced mine 4 years ago. $110 for carbon fiber clutch (not trying to sound fancy... just a regular replacement clutch), pressure plate and throw out bearing. All work myself.
Anyone with some mechanical knowledge can change a clutch with a repair manual as a guide and some common sense.
While you're doing the clutch, its an excellent time to replace that rear main seal!
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #4 of 27 Old 07-25-2007, 06:41 AM
tank29
Yeah, It's A Jeep Thing!!
tank29's Avatar
Sounds just like the time when I bought mine!!!
If you have some buddies that can help you do it it should only cost around $200-$250 depending on the quality of the clutch. I had a price quote from a small garage and it was $800...
I find BEER usually helps find friends to do this type of job!!!
Good luck.
Todd
2007 JK Unlimited "X"
TeraFlex 3" Kit with 4 Arm Flex Kit, TeraFlex HD F & R Adj. Track Bar, Rock Krawler Spring Levelers, Yukon 5.13 Gears, Black Rock Soft 8 Steel Wheels 16x8 (4.25" BS), Cooper Discoverer STT 315/75/16, XRC Rear Bumper w/Tire Swing, Rugged Ridge Front w/Stinger, AEV Snorkel, Cobra 75, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fender Flares
tank29 is offline
post #5 of 27 Old 07-25-2007, 07:12 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I am by far no expert on clutches. The only clutch I have ever changed was on an old Saab I had. But the way I understand your problem sounds to me like a hydraulic problem. My problem is the opposite. The engagement point is almost to the top of the pedal. IMHO, either my clutch and/or pressure plate is worn. Maybe someone with more expertise could clarify.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #6 of 27 Old 07-25-2007, 07:48 AM
EABiker
I would check the clutch master cylinder fluid level first; if your slave is leaking you may have sucked air into the system requiring you to bleed it. Is your pedal soft as well? That is a sure sign of air! $3.00 for a can of brake fluid!
EABiker is offline
post #7 of 27 Old 07-25-2007, 08:09 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Check for fluid on your inside firewall behind the clutch pedal.
Check your fluid level in the master cylander.
Bleed your fluid.
Changing your clutch out in the end shouldn't be too hard of a job but I would rule out these things before hand.
ALSO, Depending on what rig you have, you may need to look at the slave cylander as well.
PLEASE fill out your rig specs in your profile so we know what you have. There are about 4 different possibilities over the years of the YJ for clutch tranny etc.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 27 Old 07-25-2007, 01:15 PM
coachchuck
Just replaced mine this last week. Cost $148 for the kit from autozone. O'Rielleys wanted $314 because there slave was $169.
Cost me a long days labor, I am kinda slow at it and didn't have the exact tools needed. The top 2 bolts on the bell housing are difficult.
Will depend on year also. Is it an BA or AX, if AX is it 5 or 15?
Do check your fluids and possibly bleed the air out of the line before going to the extreme of replacing the clutch.
Can you rev the engine in gear without changing the speed of your jeep?
Chuck
Sold : 93 YJ, 33s, 4.1, HO 4.0, AX15, d300 flipped
Building 90YJ. 37s, 5.38, 350, 4L60, np241, d44-ARB, D60-spool
coachchuck is offline
post #9 of 27 Old 07-25-2007, 07:38 PM
Mr.B
Mr.B's Avatar
Originally Posted by coachchuck
Just replaced mine this last week. Cost $148 for the kit from autozone...
What all was in the kit? I know your's is an AX-15, and mine is an AX-5. But maybe they are around the same price.
Ham license:
Everyone is Welcome
Mr.B is offline
post #10 of 27 Old 07-26-2007, 04:06 AM Thread Starter
tj7695
Well, once I get it in gear it's fine, it's just getting it in gear that's the problem. The friction point is basically on the floor, and I literally have to muscle the shift into gear. I didn't have time to check anything last night thanks to work, but it's going in to the shop this morning.
88 YJ Stock
tj7695 is offline
post #11 of 27 Old 07-26-2007, 04:49 AM
rustywrangler
88 YJ Stock
definatly sounds like hydraulic so far.
post #12 of 27 Old 07-26-2007, 05:52 AM
chupacabrah
chupacabrah's Avatar
my pedal point is almost at the floor.
I"ve determined that my slave cyl is going out.
if it is the CLUTCH, then you will feel some slippage
I just bought LuK clutch kit, slave cyl, and master cyl all from clutch city online for $290 shipped.
this is the order i would check for things in:
1. check/fill/bleed fluid in master cyl
2. check for leaks around master cyl, and in floorboard near pedals
3. check for leak underneath bellhousing
4. replace master cylinder (easy/quick)
5. replace clutch and slave cyl (and possibly Rear main seal while down there...?)
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #13 of 27 Old 07-26-2007, 06:10 AM
rustywrangler
88 YJ Stock
The only other problem I see here is you still are not telling us what your rig has. 2.5 or 4.2 clutch difference is big. You also have the puegot tranny if you have the 4.2 and the ax-5 if you have the 2.5. PLEASE, fill out your rig specs in your profile. You may not think so, but it does help answer your questions. All of the info given so far is good advice to follow.
post #14 of 27 Old 07-26-2007, 10:47 AM Thread Starter
tj7695
Ok, so I couldn't even get it in gear this morning, so I had it towed to my mechanic for him to look at, I just don't have the time at the moment to work on it. Not to be dumb, but when I go into my profile to input data I can't figure out how???? The catagory's are there, just can't input data, am I just stupid???? So to answer your question Rusty, it's the 4.2 w/ puegot trans. Well, I'll see later today what the outcome is...
tj7695 is offline
post #15 of 27 Old 07-26-2007, 10:51 AM
chupacabrah
user cp -> "edit your jeep information" (on left hand side)
sounds definitely hydraulic. master and/or slave
-Jon
Average Cost On V8 Conversion Yelladog1 TJ Wrangler Technical Forum 28 04-14-2015 12:10 PM
Average cost of a ls swap? kking08 TJ Wrangler Technical Forum 2 12-21-2009 06:25 PM
average cost of a new clutch alex71 TJ Wrangler Technical Forum 11 06-08-2007 10:49 AM
Average cost for alignment after REBB? Falcor TJ Wrangler Technical Forum 16 11-12-2004 07:01 AM
Average cost to replace clutch in 94 4.0? Tony1 YJ Wrangler Technical Forum 4 12-10-2003 11:11 AM
