Autometer Speedo Swap, Redux - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Autometer Speedo Swap, Redux
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIron Rock Offroad products - get them from Kolak!TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/
Unread 04-07-2015, 06:33 PM   #1
reeveskd
I need some specific help, because I've re-read the speedo threads here a few times, and am not having success.
I have an Autometer Phantom 5892 120 MPH mechanical speedo. I read here in F12 that to connect this to the '89 YJ, I would need a replacement 83" speedometer cable with a 5/8" nut on top and a 7/8" nut on the bottom for the NP231 connection. I went to AutoZone and NAPA, and both of them looked at me like I was insane when I asked them about the cable.
So here's the deal: I am totally willing to send the mechanical back and get an electronic if that's what people recommend, which seems to be the case. What I need to know, specifically, is EVERYTHING that I need to order to make sure this thing works. (I'm on vacation, so if I can rush-ship the stuff here, I can do this before I drive home!) So, sorry to be a pain - I've been asking a lot of rapid-fire questions these past few days because I'm time-limited - but I'd love some confirmation so I can do this right. Everybody's been SO great, and I appreciate everyone's time
Electronic speedo: Autometer Phantom 5887 (3 3/8" electronic)
Hall effect sender unit: Autometer 5291
If I buy these two items, do I have everything I need? The plastic connector at the top of the existing speedo cable (white plastic) can be seen in the slightly-fuzzy background here:
Does the Hall effect sender 5291 connect directly to that existing piece without an adapter or additional part?
If so, do I then wire the electrical signal wires into the 5887?
Sorry for the overly-specific questions. I really want to be sure I order *EVERYTHING* I need this time. If there's a cheap and easy way to get the mechanical speedo I have now (Autometer Phantom 5892) to connect up with a couple of ordered parts, I'm interested in that, too. I'm not afraid of the work at this point; just afraid I'll end up without what I need, 'cause I keep running into dead ends.
THANKS!
reeveskd is online now   Reply With Quote Quick reply to this message
Unread 04-07-2015, 07:49 PM   #2
T800
Part number 4030
http://www.transmissioncenter.org/speedometer_cable.htm
T800 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 08:27 PM   #3
reeveskd
Thanks, T800; I think I'd been directed to this site, but wasn't sure exactly what to look at. That's a perfect, simple, inexpensive answer for the mechanical.
For shifts and giggles, can anyone comment to the appropriate needed equipment to go electronic?
Unread 04-07-2015, 09:07 PM   #4
T800
The sending unit you linked to looks to me like it'd work just fine. That Autometer stuff is a bit pricey, IMO.
Check out Speedhut. I've used them in motorcycles - it's a solid gauge with lifetime warranty.
http://www.speedhut.com/gauge/G338-S...h-programmable
Customize to your liking.
And a sending unit ...
http://www.speedhut.com/ecommerce/pr...magnetic-pulse
Unread 04-08-2015, 12:04 PM   #5
Rebel442
You can also call up this place, they can make any cable you need. Cost was about $50 to make mine when I did the autometer install. My stock cable however did not measure 83" my cable was 93". Maybe due to auto trans? They sent me a super nice heavy duty cable.
www.speedometersolutions.com
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline   Reply With Quote Quick reply to this message
