Autometer Electric speedo hookup
Converted all the gages to Autometer. All but the speedo worked great.
The VSS signal is via an white with orange tracer. However that wire is buffered by the PCM. Which Autometer says will not work. It needs a clean signal from the sender BEFORE the PCM.
My wiring diagrahm shows the white with orange coming from the VSS on the trans TO the PCM. Then the same orange and white up to the gage cluster FROM the PCM.
Yep I have no orange and white feed wire to the PCM. Any ideas on what colors I should be looking for ?
Thanks !!
