Auto vs manual wiring harness - JeepForum.com
post #1 of 5 Old 04-21-2017, 09:46 AM Thread Starter
spoiler73
1987 YJ Wrangler
Is there a difference between the 2 harnesses? If I had a manual and the harness was no good, would I be able to use a harness from the auto and everything still work? Including the check engine light?
spoiler73 is offline
post #2 of 5 Old 04-21-2017, 10:26 AM
Chrisnvegas
Chrisnvegas's Avatar
The auto has a neutral/ park switch.
And maybe a lockup torque converter wire if equipped.
Pretty easy to work around those though.
not sure about the manual trans upshift light.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #3 of 5 Old 04-21-2017, 10:59 AM
Que89YJ
The answer is yes. You need to worry about the changes in between the years. The auto/manual is the same. NSS wiring is on both.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 5 Old 04-21-2017, 11:25 AM
Chrisnvegas
Isn't the NSS just a ground anyway?
Henry Ford
post #5 of 5 Old 04-21-2017, 12:35 PM
Que89YJ
Yes. On the manual they just loop the ground instead of making a new harness.
Fault codes:
No Start:
Que89YJ is offline
