auto transmission problems - JeepForum.com
post #1 of 5 Old 08-16-2013, 10:02 PM Thread Starter
billy_butler
alright fellas, i just picked up a sweet half way done project/headache. its a 95 yj with a SBC swap, they also did me a favor and tossed a turbo 400 in it. along with a sweet three inch body lift now to the issue, i was down grading my 3 in BL to a 1 inch cause there was tons of clearance that was not needed. the aftermarket radiator needed to get reworked for clearance issues with the steering box. when i took the tranny lines off there was no tranny fluid in the radiator not a drop. so my question is. what could cause this problem? its shifting fine and if i wouldnt have taken the lines off i would have never known anything was wrong with it... is there some sort of check valve or something that would stop fluid flow? i have searched the web high and low. i know this is a popular swap so maybe someone knows whats up... any ideas would be great.
billy_butler is offline
post #2 of 5 Old 08-17-2013, 12:02 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If it ain't broke...
Luck Favours The Prepared
Anticanman is offline
post #3 of 5 Old 08-17-2013, 02:18 AM
Dingo1033
X2 to Anti. I've replaced radiators on auto trans cars that I've only gotten a few drops of trans fluid or none at all. Others have bled like a stuck pig. If everything works/runs/shifts fine, check the fluid and continue on as usual. If it ain't broke, don't fix it.
"I may not change the world, but I'll damn sure leave a scar"
Dingo1033 is offline
post #4 of 5 Old 08-17-2013, 06:59 AM
kahanabob
take one line off and start it and put in N and see if fluid comes out?
kahanabob is offline
post #5 of 5 Old 08-17-2013, 11:36 AM Thread Starter
billy_butler
thanks alot fellas. its all good, turns out some trannys drain back into the pan when the pumps not running. thanks again.
