Auto transmission to manual transmisson swap. - JeepForum.com
post #1 of 4 Old 02-19-2014, 01:43 PM Thread Starter
raber88
Hey guys,
First off I would like to say thanks for all the great information on this thread! Although I am a new member I have been searching this thread for months.
Anyway, I have a 1994 Jeep Wrangler YJ 2.5L with an auto transmission. The engine and transmission are both getting weak and I need to be planning for the future. I have found a guy selling a 1991 Jeep Wrangler YJ 2.5L engine, transmission, and transfer case online.
If I made the swap I would change everything, engine, transmission, and transfer case. My question is what will I be looking into if I did make the swap like this? Should everything in theory bolt up? What would I need to look into with switching an auto to a manual? Thanks in advance for all your help!
raber88 is offline
post #2 of 4 Old 02-19-2014, 02:09 PM
Rproject
1987 YJ Wrangler
First off - WELCOME from the shadows into the light.
Second, what transmission is bolted up to the 2.5 for sale? The AX-5? If so, a word of caution, 5th gear in the AX-5 is held in place with a C-clip that has a tendency to crack allowing 5th gear to slide away giving you a 4 speed transmission. Also, the AX-5 isn't the strongest trans out there. If it's an AX-15, you're golden.
As for the swap, you're going to need to get a new steering column. One without the shifter on it. I believe, but I'm sure those with more knowledge will chime in, there's some wiring that has to get changed around as well. I thought about going down this road with my rig and was advised that it was more of a job than it was worth. Not sure how valid the statement was.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 4 Old 02-19-2014, 03:27 PM
sprngrider
It depends if the ax-5 that comes with it is in good shape. You will need the clutch hydraulics, as well. It will be an internal slave, which is lame. A 4.0 swap would be worth the effort.
1994 2.5L WRANGLER S.
sprngrider is offline
post #4 of 4 Old 02-20-2014, 08:21 AM Thread Starter
raber88
Thanks for the replies guys. I think I am going to hold off on this purchase. I'm just gonna run my current set up until it quits and go from there.
raber88 is offline
