Auto tranny help. - JeepForum.com
post #1 of 1 Old 04-05-2010, 07:52 PM Thread Starter
yellow2kgt
Auto tranny help.
I had my TF999 rebuilt 3 years ago and it shifts and runs great. However, The last three times I have had it on the interstate for more then a few miles it blows fluid out when I slow down. I can drive at 65 for 30 minutes straight with no problems but when I pull off on the exit I am rewarded with a huge nascar like smoke plum. I am running an external cooler so I don't think it is over heating. The fluid is nice and pink and smells good as well. I can clean it up and drive it for several weeks around town without a single drop leaking out. But, I run it at 3 grand for an extended time slow down and huge fluid spray. It is almost like the tranny is building pressure and is not releasing it properly when slowing. I am still running the factory vent BTW. I will admit I should probably check the fluid level. I can't see that it is over filled as it ran fine for three years.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is online now
will an auto cherokee tranny fit my auto 89 4.2 wrangler???? Nate M YJ Wrangler Technical Forum 4 05-01-2008 06:45 PM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 06:35 AM
Who has replaced there auto tranny fluid in a 3 spd auto? and who did the deeper pan? cb19950 TJ Wrangler Technical Forum 4 09-01-2007 06:27 PM
auto/auto tranny swap...opinions? BillR TJ Wrangler Technical Forum 2 06-08-2007 09:54 AM
Auto Tranny/Tranny Cooler Q FlexyTJ TJ Wrangler Technical Forum 3 05-21-2005 10:17 PM
