Auto np-231 fit ax-15? - JeepForum.com
post #1 of 6 Old 03-11-2010, 03:50 PM Thread Starter
provinT13
Will the np-231 out of a 99 TJ fit into a YJ or XJ ax-15? Are the input shafts different lengths or splines?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #2 of 6 Old 03-11-2010, 04:06 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
According to the TJ Stock specifications page, the only one listed as having the smaller output shaft is the AX-5. So my educated guess is that it will work with your AX-15.
http://www.jeepforum.com/forum/f9/st...ations-452871/
Edit: Is it out of a 4cyl auto or a 6cyl auto? 6cyl auto is 23 spline. 4cyl auto is unknown, as its not listed on that page for output shaft size.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 6 Old 03-11-2010, 04:09 PM Thread Starter
provinT13
Where do you see that? I don't see anything listed under t-case for length. What about a cherokees
post #4 of 6 Old 03-11-2010, 04:11 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Originally Posted by provinT13 View Post
Where do you see that? They don't even have np-231 listed as t-case.
NP231 = NV231. New Process Gear changed their name to New Venture Gear. I was looking at the transmission post, where their output shafts were listed as all being 23 spline for the 6 cylinder transmissions.
-Matt
White '94 YJ Sport
UltimatE is offline
post #5 of 6 Old 03-11-2010, 04:41 PM Thread Starter
provinT13
Ah alright. What about an np-231 behind an aw-4 on a cherokee?
post #6 of 6 Old 03-12-2010, 12:57 PM Thread Starter
provinT13
Bump. What about the np-2321 behind an AW-4 on a cherokee?
*edit* Just saw this
http://www.novak-adapt.com/knowledge...nput_gears.htm
So the t-case from the aw-4 is only 21 sline short shaft. I need 23 spline short shaft. The only way I can get one is from an ax-15
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 10:30 AM
***Simple: can I swap in a TF999 auto transmission into my 2.5L auto? phelan YJ Wrangler Technical Forum 2 02-07-2010 01:54 PM
will an auto cherokee tranny fit my auto 89 4.2 wrangler???? Nate M YJ Wrangler Technical Forum 4 05-01-2008 07:45 PM
Who has replaced there auto tranny fluid in a 3 spd auto? and who did the deeper pan? cb19950 TJ Wrangler Technical Forum 4 09-01-2007 07:27 PM
auto/auto tranny swap...opinions? BillR TJ Wrangler Technical Forum 2 06-08-2007 10:54 AM
