Auto Meter Gauges Install ? - JeepForum.com
post #1 of 9 Old 08-28-2007, 05:45 AM Thread Starter
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
I am starting the install and on the fuel gauge I got the 0 empty/ 90 full I have a 4.0 in it now and it came with the 258 and has a 20 gallon tank. I wonder if the 0/90 is for the 15 gallon tank?What the gauge is doing it is reading higher than what it should! Did I get the wrong gauge? Any one no if I have the right gauge or which one I need?
And I just installed a new factory sending unit.
Poor People Have Poor Ways!
DaSham58 is offline
post #2 of 9 Old 08-28-2007, 08:43 AM
YJ-Mike
Do you have a multimeter? If so, pull the sending unit from the tank, and measure the resistance with the float all the way up (full tank), and all the way down (empty tank). That is the best way of knowing for sure exactly which gauge you need.
This is from the FSM for my 04 4.0L:
NOTE: For diagnostic purposes,
this 12V power source can only be verified
with the circuit opened (fuel pump module
electrical connector unplugged). With the connectors
plugged, output voltages will vary from
about 0.6 volts at FULL, to about 8.6 volts at
EMPTY (about 8.6 volts at EMPTY for Jeep
models, and about 7.0 volts at EMPTY for
Dodge Truck models).
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #3 of 9 Old 08-28-2007, 09:38 AM Thread Starter
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
I called AutoMeter and they said that I had the right gauge and said for me to run new wires from the tank up. Thanks for the info.
DaSham58 is offline
post #4 of 9 Old 08-28-2007, 10:31 AM
coyote_94yj
coyote_94yj's Avatar
I have the same gauge in mine and it does seem to be just a little higher. I just left it that way. Although if I ever need to drop the tank for anything, I will probably just make a small adjustment to the float to compensate.
Chris
coyote_94yj is offline
post #5 of 9 Old 08-28-2007, 10:58 AM
Ares
Ares's Avatar
What exactly do you mean "the gauge is reading higher then it should?" Are you talking about when full, the needle passes the F, or stays on F for a while? Or when empty the needle still reads you have sufficiant fuel.
Most sending units will read full for a while, because the amount of fuel put in the tank will fill past the sending unit. After about 50 miles, the fuel level will drop enough for the sending unit to start to read it.
Also, when you ran new wires, be sure you ran a new ground. Grounds are the culperate of a lot of electrical issues.
And you can check the ohms of your sender with a cheap multimeter. Just slice the coating open on the wire, connect the mutimeter in parallel with it, and look at the ohm reading. Do it when full, then run it down to near empty and do it again. It should be 0 empty, 89 full. The sending unit ohm reading I highly doubt changed between tank sizes, since then the gauge cluster would need to change since the fuel gauge in there would have to read at different ohms. The sending unit is just longer.
- Cameron
Ares is offline
post #6 of 9 Old 08-28-2007, 01:16 PM Thread Starter
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
I had between a half and 3/4 of a tank and when I hooked the gauge up it reads right at the full mark!So I went and filled the tank up and now it went way past the full mark. I called A/M and he had me do a test on the gauge he thinks the gauge is bad.He had me to unhook the sending wire from the gauge and then ground the sending part of the gauge. He said it should go to empty and it just went to a 1/4 of the tank. I will say one thing they sure have a good customer support that is for sure!He also said it might take the Chrysler one which is 73 Ohm empty/ 8-12 Ohm full?
DaSham58 is offline
post #7 of 9 Old 08-28-2007, 03:33 PM
Ares
Ares's Avatar
Thats pretty cool that they took you through the steps to check out the gauge. It does sound like a bad gauge. I don't think it would take a 73-8ohm sending unit, but if anyone knows for sure feel free to chime in.
- Cameron
Ares is offline
post #8 of 9 Old 08-28-2007, 04:23 PM Thread Starter
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
That's pretty cool that they took you through the steps to check out the gauge. It does sound like a bad gauge. I don't think it would take a 73-8ohm sending unit, but if anyone knows for sure feel free to chime in.
It is hard to find places with this good of customer support they offered to send me another gauge but I told them the place that I got the gauges would have me one tomorrow He is also going to order the 73/8ohm gauge to see if it is the right one.I hope this works this is all I am waiting on to finish.
DaSham58 is offline
post #9 of 9 Old 08-28-2007, 10:29 PM
rollerized
Sent you a pm
rollerized is offline
Auto Meter Gauges DaSham58 YJ Wrangler Technical Forum 16 08-01-2017 07:41 AM
Auto Meter Speedo Install ???? scubamc YJ Wrangler Technical Forum 4 04-30-2011 08:55 AM
Auto Meter Speedo Install Questions jeremy91yj YJ Wrangler Technical Forum 1 04-24-2009 09:27 PM
check gauges lit..voltage meter tops to 19 and wont start! kittennocturne TJ Wrangler Technical Forum 0 03-03-2009 06:17 PM
problems after auto meter install flys_yj YJ Wrangler Technical Forum 5 03-30-2008 03:34 PM
