Auto Meter gauges in factory bezel? - JeepForum.com
post #1 of 10 Old 11-22-2011, 08:17 PM Thread Starter
Jeepfan1
Is it possible or has anyone upgraded their gauges to Auto Meters and kept the factory gauge pod?
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #2 of 10 Old 11-22-2011, 09:13 PM
timatoe
timatoe's Avatar
It is possible. There was a guy on eBay selling a panel that would allow you to use after market gauges behind the stock plastics. I bought one of these but later sold it to another member here. I ended up using the gauge cluster from AutoMeter instead.
timatoe is offline
post #3 of 10 Old 11-22-2011, 10:16 PM
jbolty
jbolty's Avatar
I replaced the clock with a transmission temp, center position.
jbolty is offline
post #4 of 10 Old 11-22-2011, 10:43 PM
AnonymousD
The PO of my jeep cut some wood trim pieces and glued them to the bezels. Then cut holes where the gauges went and put them through like that.
I do now recommended this method though. lol
AnonymousD is offline
post #5 of 10 Old 11-23-2011, 04:49 AM Thread Starter
Jeepfan1
This is exectly what I need then. My Jeep has all new dash palstics in it but I would like to change to Auto Meters and still keep all the factory dash.
Ive done some browsing on eBay for that piece but im coming up empty, also im told a company named drivetrain unlimited sells a panel that holds the gauges in the factory dash however I cant seem to find them. Does anyone have a lead where to source one?
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #6 of 10 Old 11-23-2011, 06:56 AM
scubamc
Ditch the plastic for some metal.
https://sites.google.com/site/double...ngler-yj-dashs
scubamc is offline
post #7 of 10 Old 11-23-2011, 02:31 PM Thread Starter
Jeepfan1
Originally Posted by scubamc View Post
ehh I saw that but not really an option for me in this Jeep
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #8 of 10 Old 11-23-2011, 03:18 PM
timatoe
timatoe's Avatar
Here's a pic of the one off eBay....
It would seem that it would be easy enough to build one if you've got the ability. That panel just screws to the main dash then the plastic goes over it.
timatoe is offline
post #9 of 10 Old 11-24-2011, 06:01 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I have the one from Drivetrain Unlimited, it worked great. There is a pic in my gallery I think. They are in St George, Utah. I'll try to find. The number as they didn't have a web site.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #10 of 10 Old 11-24-2011, 08:35 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I found it: Drive Train Unlimited Incorporated(435) 673-4115
3714 S 1700 E, St George, UT 84790
5.7YJ is offline
Auto Meter Gauges DaSham58 YJ Wrangler Technical Forum 16 08-01-2017 07:41 AM
98' Wrangler Check Gauges light on, volt meter is at bottom Reddot44 TJ Wrangler Technical Forum 5 01-20-2012 09:49 PM
Auto Meter Tach Gauge Fit in Stock Bezel? Jim93YJ YJ Wrangler Technical Forum 1 03-27-2010 02:14 AM
check gauges lit..voltage meter tops to 19 and wont start! kittennocturne TJ Wrangler Technical Forum 0 03-03-2009 06:17 PM
Auto Meter Gauges Install ? DaSham58 YJ Wrangler Technical Forum 8 08-28-2007 10:29 PM
