auto to manual swap Help!!!! - JeepForum.com
post #1 of 13 Old 03-30-2010, 06:57 PM Thread Starter
solobericl5
Ok,so here it is, first off i love all ur answers you guys know ur stuff. Neways, i have a 95 wrangler yj. It was an automatic, my buddy has a parts jeep (93 yj manual). Both have the 2.5 only difference im auto and he is manual. I decided to take all his components and transform mine into a manual. Installation was smoothe and everything is done. Went to start up the jeep. It fired and idles normal. When i shift into 1st,2nd,3rd,and 4th i could do so with or without engaging the clutch and the jeep doesnt move. Now when i try shifting into 5th or my reverse gear i have to engage the clutch or it will grind. When i let the clutch out you could hear the tranny spinning inside but the jeep still wont move. If you put it in gear and push it it isnt stopped by the tranny being in gear. Im told that it might be the throw out berring sticking, making the clutch unable to grab back onto the flywheel, or is it the clutch and the slave making it incapible of catching into gear. I figured id ask because it is 200 dollars to replace the clutch and the slave. Ne ideas?
Ride hard, or ride home
solobericl5 is offline
post #2 of 13 Old 03-30-2010, 07:00 PM
Burnerman
Burnerman's Avatar
Is the transfer case in neutral?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 13 Old 03-30-2010, 07:35 PM Thread Starter
solobericl5
yea, neutral hi or lo no difference : (
post #4 of 13 Old 03-30-2010, 07:42 PM
Burnerman
Burnerman's Avatar
Hmmm. Did the trans work before the swap? You said it was a parts Jeep? Sounds like something is broke in the trans.
96 ZJ.
post #5 of 13 Old 03-30-2010, 07:54 PM Thread Starter
solobericl5
Yea, he snapped the frame rails in 2 places, bought a new one and uses that one for parts. Everything sounds normal when its in gears and all. Idk it just seams like the clutch isnt grabbing onto the flywheel and we bled the clutch line
post #6 of 13 Old 03-30-2010, 08:22 PM
KnacK
You did swap flywheels right????
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline
post #7 of 13 Old 03-30-2010, 08:27 PM Thread Starter
solobericl5
yea. i even had napa resurface the flywheel for 30 bucks
post #8 of 13 Old 03-31-2010, 01:01 PM Thread Starter
solobericl5
now the tranny spline spins with the tcase off. im starting to think the auto tcase is different from the manual tcase
post #9 of 13 Old 03-31-2010, 01:55 PM
MoparFreak69
Yes, the ax-5 manual has a 21 spline output shaft where the TF auto you took out has 23. The ax-15 has 23 also. You need to either find an input shaft for your transfer case that is 21 spline, find a 21 spline transfer case, or throw an ax-15 in there. I'm surprised you got it to go together!
MoparFreak69 is offline
post #10 of 13 Old 03-31-2010, 03:02 PM Thread Starter
solobericl5
lol.me 2. how much do those things cost from a yard. im thinkin like 100. since i gotta drop the trans again 2 imma put a fresh clutch and slave cylander in there 2 im done ****tin around with this thing lol
post #11 of 13 Old 03-31-2010, 03:13 PM
MoparFreak69
A yard that I frequent I can probably pull one for like $20. Your mileage may vary, but I wouldnt imagine much more than about $100. I would find a cherokee/comanche that has a 4 banger and a manual trans as wranglers are non-existant in yards around here. As soon as they hit the ground (once in a blue moon) they are stripped clean.
A couple years ago I managed to find a body tub, had to buy it immediately as there was 2 guys in line behind me asking about it. The yard had just set it in its spot 2 hours before. A week later we picked up the frame for my old man, only reason it was around still was that there was a bunch of mounts cut off it and people didnt think it was worth the work.
post #12 of 13 Old 03-31-2010, 04:54 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
Put in a new flywheel while you are in there.
They machined it flat and flywheels are supposed to have a bevel.
Check out Dial-A-Clutch - Your LuK Clutch Kit Specialist for good prices on LUK clutches and flywheels.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #13 of 13 Old 04-03-2010, 06:56 PM Thread Starter
solobericl5
thanks alot guys. got it runnin, turned out the transfer case was the source of all my problems. next project is frame swap : ) o joy lol.
Manual to Auto swap? mike481 TJ Wrangler Technical Forum 17 03-21-2010 09:24 PM
97 TJ - Manual to Auto Swap. MisterO TJ Wrangler Technical Forum 17 08-17-2009 08:33 AM
Tj auto to manual swap mm4423 TJ Wrangler Technical Forum 14 08-22-2007 09:49 AM
Manual to Auto Swap? FSJMike YJ Wrangler Technical Forum 5 09-19-2006 11:45 PM
Manual to Auto swap... Parabola YJ Wrangler Technical Forum 0 07-15-2004 08:24 PM
