Auto dimming rearview mirror with compass and temperature install - Page 5 - JeepForum.com
post #61 of 110 Old 08-18-2013, 05:51 PM
jhigday
2016 JK Wrangler
so... the 50 model is too heavy or all? sorry confused.
http://www.jeepforum.com/forum/f9/tj-tech-boot-camp-must-read-new-tj-owners-forum-members-722109/
jhigday is offline
post #62 of 110 Old 08-18-2013, 05:59 PM
jhigday
2016 JK Wrangler
mirror weight is 2.1 pounds. that too heavy?
jhigday is offline
post #63 of 110 Old 08-18-2013, 06:05 PM
Gage56
Here i just thought i would add this if anyone is looking to buy one on ebay
for the GM Compass Mirrors there is a Zone setting and if it is not set for the right zone it will not display right so here is the zone codes
1-upper Canada and Alaska,
2-Mid to lower Canada,
3-Washington State Oregon Idaho
4-California Nevada
5-Hawaii West Texas and all states directly above Texas on map
6-East Texas and all states above that on map,
7-Mississippi ALabama Illinois
8-Florida Georgia Tennesee Kentucky Indiana
9-North/South carolina Weat Virginia Ohio Michigan
10-Deleware Wash DC NJ Philidelphia Pennsylvania
11-Conneticut MASS New York MOntreal
12-New Hampshire Vermont Maine Nova Scotia New Brunswick
13,14,15 Quebec
1992 YJ
Gage56 is offline
post #64 of 110 Old 08-18-2013, 06:11 PM
jhigday
2016 JK Wrangler
Thanks Gage. That will be helpful for sure. I'm trying to decide what mirror to get off Ebay. the Jeep sites want 400+ for OEM versions
jhigday is offline
post #65 of 110 Old 08-18-2013, 06:19 PM
czjeeper
I was just adding some feedback for the mirror I bought.
Not necessarily too heavy, if you don't take hard hits a lot!
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #66 of 110 Old 08-18-2013, 06:38 PM
jhigday
2016 JK Wrangler
cool. Just wanted to make sure I didn't do something stupid lol
jhigday is offline
post #67 of 110 Old 08-30-2013, 06:52 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
If your worried about it cracking the mirror, I have seen a mod where some one took flat stock and welded it to the upper windshield frame and then attached the mirror button to that. Heavy mirror problem solved!
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #68 of 110 Old 08-30-2013, 07:52 AM
Gage56
Originally Posted by deathtrap View Post
I got less then $15.00 in mine.
Ahh yes, this is why i love my junk yards i got 2 of them and a half door mirror for less than 15.00 with all the wires
1992 YJ
Gage56 is offline
post #69 of 110 Old 07-03-2015, 02:50 PM
kylebeau
I'm bringing this thread back just because I think it's cool
kylebeau is offline
post #70 of 110 Old 10-17-2015, 03:17 PM
DirectMatrix
It is cool. I just got done with doing this mod this afternoon. What a great improvement to my YJ. I got the mirror from PicknPull for $20 off a 2004 Saturn Vue.
I made sure to take as much of the original wire harness as possible. Same with the temp sensor. I cut the wires all the way back at the firewall...there's a connector there as well but I figured I didn't need it. The ceiling padding was already half down so I took the wiring all the way back to the rear dome light.
I couldn't get the mirror mount off the windshield of the Vue so I chanced that it would fit my stock mount on my 1992 YJ and it did. Just crank the set screw down a little extra
I ran the wiring through the windshield frame and used brake line bleeder valve covers as a makeshift grommet. Worked like a charm. I fished the bundle down through the existing hole where the wiper motor sits. I used 12v switched power that I had previous tapped off the radio I think as well as a ground at the same location. I then ran the two temp probe wires through the existing firewall boot and married them up with the wires from the probe itself. I made the splice right near the washer bottle reservoir and the temp probe is under the driver's side fender and uses the existing headlight harness loom clip to hold it in.
All in all, about 4 hours worth of time, not including the trip to the JY. Well worth it though...between this mod and the intermittent wiper mod, I feel like I'm driving a car from this century!
DirectMatrix is online now
post #71 of 110 Old 10-17-2015, 03:37 PM
14Sport
Proud Deplorable
14Sport's Avatar
Good job. I added a Tahoe mirror myself and mounted the temp probe in front of the radiator. Like you said, feels more modern.
What is this intermittent wiper mod you speak of? I haven't heard of that one and sure could use it on my 1995 YJ. Is there a write-up you followed?
Thanks.
My observations are based on my experiences...YMMV.
14Sport is offline
post #72 of 110 Old 10-17-2015, 04:11 PM
DirectMatrix
http://www.delawareja.com/forum/index.php?topic=5140.0
I hate to link to another forum, but I didn't find any on JF.
Word of caution. The intermittent wiper mod is a PITA. Extensive, tedious and time consuming. Working under the dash is very space limited.
Good luck.
~DM
post #73 of 110 Old 10-17-2015, 04:31 PM
14Sport
Proud Deplorable
14Sport's Avatar
Good luck.
~DM
Haha...appreciate it! I've been looking for a reason to pull my column apart and replace switches. I think you just provided that.
14Sport is offline
post #74 of 110 Old 10-17-2015, 04:42 PM
DirectMatrix
Not to hijack this thread, but...while you're at it, replace the turn signal switch for sure. Also, pay particular attention to the way the horn diaphragm comes out and the orientation of the highbeam switch/rod.
Good luck
post #75 of 110 Old 10-18-2015, 08:17 AM
rustisexpected
Good luck.
~DM
I have completed this conversion to 3 YJ's and have never needed to swap the switch in the column. I have gone to the JY and pulled a lever from a square body S10 and the intermittent box from an XJ and installed both without any further mods. Cost under $10 this way.
Rusty's build thread - http://www.jeepforum.com/forum/f22/project-jermey-1806881/
rustisexpected is offline
