aussie locker question - JeepForum.com
post #1 of 15 Old 12-09-2008, 05:26 PM Thread Starter
plyguitar45
ok i was looking at the aussie locker and had a few questions.
i did a search and couldn't really find anything.
sorry if i missed something.
but i was looking at buying an Aussie Locker for my front axle and it says on their site that if i have a limited slip/posi carrier than i will have to replace it with an open carrier.
so what do i have? everything is pretty much stock in this area.
also, just to clarify, having this locker means that whenever i engage 4wd, then the locker will be engaged?
thanks!
- New Jeep :D-
3.7L '04 Manual Liberty KJ, all stock
-SOLD MY JEEP :(-
2.5L Red '91 YJ w/
, 2" BL, 31" MT Baja Claws, Superwinch LP8500, RH4x4 Front Bumper, JKS Quick Disco's, Rampage Nerf Bars
plyguitar45 is offline
post #2 of 15 Old 12-09-2008, 05:36 PM
provinT13
You already have an open diff unless the previous owner put a limited slip in there. The locker will be engage itself when it needs to, that's why it's a non selectable locker. But if you're not in 4wd then the front drive shaft isn't spinning so it's not going to be doing anything (to my knowledge, someone correct me if im wrong)
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 15 Old 12-09-2008, 05:37 PM
MLJeeper
MLJeeper's Avatar
Youre Dana 30 is open if its stock.
Correct, when torque is applied it will lock.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #4 of 15 Old 12-09-2008, 05:42 PM Thread Starter
plyguitar45
ok thanks.
also, it says it doesn't work for "Dana 30a or Next Generation Differentials"
i'm pretty sure i don't have one of those, correct?
- New Jeep :D-
-SOLD MY JEEP :(-
2.5L Red '91 YJ w/
post #5 of 15 Old 12-09-2008, 07:17 PM
95greenrio
I'm pretty sure the Dana 30a is the ifs version. Either way, the one they have listed on their site will work in your Jeep.
1995 YJ Rio Grand - work in progress
95greenrio is offline
post #6 of 15 Old 12-09-2008, 07:43 PM
ritjobbie
I just installed an Aussie in my D30. It should be invisible when you are in 2WD. The locker will cause your front driveshaft to spin all the time (like a TJ). Unlike a TJ, the YJ front DS is not balanced from the factory. You might get some slight vibes. No biggie. It happened to me. I'm dropping off my DS to get balanced soon enough.
Once you put the locker together, you'll really understand how it works. I'll give it a shot, though:
The locker is always 'locked' under normal circumstances. When you aren't applying tons of torque to the axle, the gears in the locker are kept together only with the force of four small springs. When you go around a corner, the force of the springs is easy to overcome and one wheel is allowed to go faster. When you jam on the gas (or when one wheel slips) the gears in the locker try to rotate past the pinion shaft (cross shaft), but they can't and instead the gears engage engage really hard, thus locking the axle.
Since the passenger axle disconnects when you are in 2WD, the locker won't interfere whatsoever with your normal driving. You'll only notice amazing traction in 4wd.
It probably took me longer than most to install mine--I fixed some other front-end problems along the way. I could probably do it in 2 hours a second time around. Take your time and keep everything clean.
Do it, you'll be happy.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #7 of 15 Old 12-10-2008, 12:23 AM
RikRotorhead
^^What he said is correct. The front drive shaft will spin all the time.
If you flat tow your Jeep, the drive shafts are connected together inside the transfer case in 4wd AND neutral, but not in 2wd. So if you put the t case in neutral, it will cause the Jeep to tow funny, and cause problems.
Solution(s):
1. disconnect the front drive shaft at the D30 yoke and tie it up
2. engage the right half of the axle if you are going short distance and you have an automatic transmission. It will scuff the tires a bit tho'.
3. leave the t case in 2wd, place the transmission in neutral only on a stick shift trans.
4. put it on a trailer.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #8 of 15 Old 05-13-2009, 08:17 AM
Bigdogk9
What if the passenger two piece axle has been replaced with a one piece and the air actuator removed. What problems will one see with the Aussie locker?
Bigdogk9 is offline
post #9 of 15 Old 05-13-2009, 08:43 AM
Louie4
"You pass butter"
Louie4's Avatar
In that case you will probably only hear clicking noises when turning, with the window or top down, going slow. Otherwise, not much difference. It will put more 'wear' on it I guess, but no more than what a rear locker does. Shouldn't make or break the decision to do it though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #10 of 15 Old 05-13-2009, 08:45 AM
ritjobbie
I know plenty of TJ guys run an Aussie up front (no axle disco). A friend of mine runs front and rear lunchbox lockers in his XJ. I've heard stories of wheels locking up funny on icy highways, but I can't really speak from experience. I would assume that under normal circumstances, the side gears will be allowed to ratchet during corners because in 2WD there is no load on the front driveshaft.
I'm sure if you lurk in the TJ forum for a few minutes you'll get a better answer.
post #11 of 15 Old 05-13-2009, 09:17 AM
Bigdogk9
Thanks for the replies. I'm going to proceed with the install. When I replaced the axle I had my front drive shaft balanced to stop some minor vibration.
Bigdogk9 is offline
post #12 of 15 Old 05-13-2009, 10:47 AM
Beater37887
I just replaced my front axle with a one piece and at the same time installed an Aussie. I have had no problems driving it on the highway and don't even notice its there. You will however notice a great difference in traction on the trails, best upgrade I've done. You will also hear it popping on the trail from time to time, once you get used to it that's no big deal, its not loud. I didn't have any problems with the balance on my front ds so I didn't bother getting it balanced, couldn't feel any more vibration than before because of the the tires. Install was really easy and just a matter of keeping everything clean. Good luck and enjoy!
Beater37887 is offline
post #13 of 15 Old 05-13-2009, 11:05 AM
lclark2074
On a 30 the driveshaft will turn all the time in 2WD or 4WD becuse there is know wheel disconect on the driver side
lclark2074 is offline
post #14 of 15 Old 05-13-2009, 11:35 AM
fyrdriver
1983 CJ7
Not true, the carrier spins in the diff and with the axle disconnect there is no resistance from the pass side. I know this because I too had to balance my driveshaft after getting my aussie.
Firefighters Jeep Club
fyrdriver is offline
post #15 of 15 Old 05-13-2009, 12:25 PM
timatoe
timatoe's Avatar
True, this is actually the reason behind the stock disconnect system on the passenger side.
timatoe is offline
Aussie Locker Question HoustonTJ TJ Wrangler Technical Forum 8 02-21-2009 07:14 PM
Another Aussie Locker Question 172heavy TJ Wrangler Technical Forum 17 01-12-2009 02:46 AM
Aussie Locker question jmhat98 YJ Wrangler Technical Forum 4 04-28-2007 10:14 AM
Aussie Locker Question 2004Jeeptj111 TJ Wrangler Technical Forum 18 03-08-2007 05:30 PM
question about (aussie) locker Dennisr YJ Wrangler Technical Forum 6 08-08-2005 07:27 PM
