August YJOTM winner is E_ROCK!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > August YJOTM winner is E_ROCK!!
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Closed Thread
Unread 09-03-2012, 09:18 AM   #1
Anticanman
RIP one good jeeper
Anticanman's Avatar
A big congrats to our August winner for all the hard work he's done to get this jeep to YJOTM winning standards!! Let's see some more pics and some videos of this thing in action, PLEASE!!
Here's a recap of the specs
-YJ year of production
1993
-Specifications and modifications
Engine
Stock 4.0L
Transmission/Transfer Case
Stock AX-15 transmission
Energy Suspension poly Tranny mount
Atlas 2 speed with 5.0 ratio
Centerforce II Clutch
CV rear driveshaft
Custom made square front CV driveshaft
Front axle
Wagoneer D44 axle
Spicer 4.88 gears
ARB locker
CTM u-joints
USA Alloy 4340 Chromoly shafts
Custom Axle truss
Warn Premium lockout hubs
Ballistic Fab D44 knuckle gussets
Rockcrusher Diff cover
Spidertrax 1.5 wheel spacer
Rear Axle
Wagoneer D44 axle
Spicer 4.88 gears
ARB locker
TnT Axle truss
TSM Mfg. disk brake kit
Suspension - Custom spring over axle leaf spring suspension
Front
6 stretch with relocated steering box
Alcan springs using Ruffstuff spring hangers, custom thru the frame shackle hangers, and Ground Pounder Fab boomerang 3/8 thick shackles
Energy Suspension leaf spring poly bushings
Custom 1.5 DOM shock hoops
BBCS 11 travel gas charge shocks
2" Fox air bumps
Rear
4 stretch using GenRight Crawler gas tank
Ford Ranger bastard packs using Ruffstuff spring hangers, Ruffstuff Way Back shackle hangers, and Rough Country boomerang 3/8" thick shackles
Poly Performance outboarding shock kit w/ Ballistic Fab gussets
Bilstein 14 travel gas charged 5125 series shock (255/70 valving)
Modified MORE anti-wrap bar
Custom Timbren faux air bumps
Steering
Sky Manufacturing tall high steer arms w/ cone washers, and 5/8 stud kit
1.25 x 0.28 wall DOM with 7-18tpi tapped ends
1 ton GM TREs
MORE steering box brace
Tapped Saginaw steering box for hydro assist
PSC 1.75" hydraulic assist ram assist w/ custom made mounts
Armor
Custom made 1.75 tube fenders
Custom made thick boatside rockers
Custom made Full 6 point, 1.75 tubing cage
Custom made 2x4 boxed tube cross member bumper w/ build-in hitch and frame gussets
Custom made front 2x4 boxed tube stubby bumper w/ custom winch mount
Genright Tub guards
Poison Spyder Comp Cut Crusher Corners with 3 tube flare
Custom made bellyup T-case skid plate
Custom made 1.75 tubing radiator hoop
AEV Oil Pan Skid Plate
Wheel and Tires
15 AR-23s (Spyderlock 17 6061 T-6 aluminum wheels sitting on the garage shelf)
Seats
Yonaka Samurai Synthetic leather racing seats
RCI 5 point harnesses
Custom seat mounts tied to cage
Misc
Superwinch EPi9.0 winch
Sanden On Board Air
MORE 1 lift "Bomb Proof" Motor Mounts
Energy Suspension Body mounts
AAI Speed Equipment SS braided brake lines
Advance Adapters SS braided clutch line
Custom cold air intake tube by Hanksville Hot Rod w/ Spectre air filter
Mac Custom tie-down tracks in bed
Herculined interior
Grenade shift knob
CJ swingdown tailgate
40mm ammo can console
QuickFist for spare shaft storage
Luck Favours The Prepared
Anticanman is offline   Quick reply to this message
Unread 09-03-2012, 09:25 AM   #2
bigdhamYJ
Congratulations! Sweet YJ You've got there E_Rock!
"Who knew coolant keeps the motor cool?"
Check out my Heep "build"
http://www.jeepforum.com/forum/f22/bigdhamyjs-1993-yj-build-slow-1284516/
bigdhamYJ is offline   Quick reply to this message
Unread 09-03-2012, 03:01 PM   #3
TSEJEEPERS
TSEJEEPERS's Avatar
Congrats.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Quick reply to this message
Unread 09-03-2012, 04:19 PM   #4
rtillery34
1987 YJ Wrangler
Sweet ride! Congrats!!!
rtillery34 is offline   Quick reply to this message
Unread 09-03-2012, 05:31 PM   #5
Louie4
Congrats man! I was hoping you would win. I enjoy reading your build thread.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Quick reply to this message
Unread 09-03-2012, 05:37 PM   #6
seattle_yj
Nice job man. I'll have to go back and read your build thread, see how you did all that business.
seattle_yj is offline   Quick reply to this message
Unread 09-03-2012, 09:13 PM   #7
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
Congrats big E.
An inspiration to us all
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is online now   Quick reply to this message
Unread 09-03-2012, 10:38 PM   #8
zte87
GIVE IT THE ONION
zte87's Avatar
congrats my friend I don't think there was a doubt in my mind that you were't going to win as soon as I saw you in the line up......you have a built your self a nice rig!
zte87 is offline   Quick reply to this message
Unread 09-03-2012, 10:57 PM   #9
brinoff
brinoff's Avatar
Congratulations! Looks like a fun ride.
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline   Quick reply to this message
Unread 09-04-2012, 03:26 AM   #10
jsawduste
2006 YJ Wrangler
jsawduste is offline   Quick reply to this message
Unread 09-04-2012, 03:36 AM   #11
SquidsYJ
Congratulations!
SquidsYJ is offline   Quick reply to this message
Unread 09-04-2012, 02:54 PM   #12
E_ROCK
Thanks everybody for the votes and congrats! Jeepforum has been a huge help in building up my jeep, so thanks Jeepforum!
I will try and get some more pictures and video up soon.
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Quick reply to this message
Unread 09-04-2012, 03:40 PM   #13
ldso
Sick YJ man, wow!
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline   Quick reply to this message
Unread 09-04-2012, 04:12 PM   #14
b_a_mech
Congrats! Sweet ride
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline   Quick reply to this message
Unread 09-11-2012, 01:25 PM   #15
Ksyrium
1987 YJ Wrangler
Congratulations - sweet YJ!
ΜΟΛΩΝ ΛΑΒΕ
Ksyrium is offline   Quick reply to this message
Closed Thread
