Auburn Ected or Eaton E locker - Page 2 - JeepForum.com
post #16 of 37 Old 02-17-2009, 09:01 PM
TheRealOldjeep
LOL - 600HP mustangs go in a straight line
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #17 of 37 Old 02-18-2009, 07:26 AM Thread Starter
champelite210
I'm trying to get away from being locked 24-7. No spool for me. I need a selectable locker.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #18 of 37 Old 05-02-2013, 02:24 AM
mert
i have 96 zj. i installed auburn ected locker front dana 30 . But since i changed my tires with 35x10.5x16 silverstone extreme 117 i broke my ring pinion 2 times in 2 months and i uninstalled the ected locker. İ think when it's working LSD ring and pinion couldnt resist LSD. İs there any idea or solution for this problem? Ected's installation manual it is recommended max 31'' tire for ected locker. can it be the main reason?
thanks
mert is offline
post #19 of 37 Old 05-02-2013, 10:19 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Was it professionally installed? I think your problems go deeper than your carrier choice
Luck Favours The Prepared
Anticanman is offline
post #20 of 37 Old 05-02-2013, 12:02 PM
jsipe007
Personally, I would go with eaton over the auburn. I have no personal experience with the E-locker but my buddy has one for his 44 rear and loves it.
my personal favorite is ARB. A lot of guys have issues with the ARB setup but Ive heard nothing but good from the guys who have em installed correctly and run the air line as either a hard line through the engine bay or in fuel line to protect the air line from the heat.
jsipe007 is offline
post #21 of 37 Old 05-02-2013, 12:17 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I think the OP has it figured out, its been several years since this discussion had ended.
post #22 of 37 Old 05-02-2013, 01:29 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Don't get mad at a legitimate thread necro!
At least he used the search feature and found a thread already started in which to post his question, used resized images, and asked a reasonable question.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luuca is offline
post #23 of 37 Old 05-02-2013, 01:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm fine with the resurrection, its the OP's question being answered by the subsequent posts that doesn't make sense to me. Does nobody look at the dates when they post?
post #24 of 37 Old 05-02-2013, 02:35 PM
jsipe007
Oh dang! Youre right Anti, thanks. Makes a lot more sense why he was asking Eaton vs Auburn. I know even now Eaton's seem to not have much documentation like Ox or ARB.
@Mert, just curious but what brand ring and pinion did you run?
jsipe007 is offline
post #25 of 37 Old 05-02-2013, 03:12 PM
Luuca
Luuca's Avatar
You're such a hardass. Lol
YJOTM never
Luuca is offline
post #26 of 37 Old 05-02-2013, 03:19 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Its 100* out and I apologize if I get a short fuse.
post #27 of 37 Old 05-02-2013, 03:22 PM
Luuca
Luuca's Avatar
http://www.jeepair.com/ac/4-0-liter-...linder-164.php
YJOTM never
Luuca is offline
post #28 of 37 Old 05-03-2013, 10:36 AM
mert
nitro gear ... 2 of them...3. one is again nitro gear...
mert is offline
post #29 of 37 Old 05-03-2013, 11:54 AM
mrdeath2000
Just for S&G's... if it was a front and I'd go full selectable like e-locker/arb/ox. Rear, either are ok, auburn would be cool cause you have LSD normally and locked when you need it.
I have heard some bad raps on the eaton e-locker on 8.8's, but that I THINK was the old design (back when this thread was new lol).
I got an Elocker upfront and it required SPECIAL Eaton Carrier bearings for my D30. Not sure if thats for every carrier or just the D30, so just FYI, do the research.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #30 of 37 Old 05-03-2013, 12:02 PM
HaskiE
HaskiE's Avatar
lol i see what you did there Cheer's Anti!
Edit: back on topic, I have an Ox locker, but I haven't put it in yet; they seem like the no-nonsense lockers to me. open=stock, locked=locked.
#theneverendingaxe
HaskiE is offline
auburn gear ected locker will_982 YJ Wrangler Technical Forum 4 10-19-2007 12:27 AM
Auburn ECTED Locker wdw TJ Wrangler Technical Forum 4 09-15-2007 06:55 PM
Auburn Ected electric locker FLATFENDER54 TJ Wrangler Technical Forum 3 02-01-2007 11:21 PM
AUBURN LOCKER ECTED for 8.8 skoke70 TJ Wrangler Technical Forum 2 05-04-2006 07:44 AM
