attaching piston to connecting rod - JeepForum.com
post #1 of 12 Old 09-15-2013, 02:57 PM Thread Starter
Jimidude87
Hey guys i just had a quick question...I recently started rebuilding my motor and while i had it apart i noticed one of the pistons was cracked...i bought a new one and was told i could use the old connecting rod...i have an arbor press and from what i have researched that's all i need to mate the two...now I'm hearing that i need to take it to a machine shop so they can heat something while they connect them...is this true or can i just do it myself with the arbor press?
Thanks guys
Jimidude87 is offline
post #2 of 12 Old 09-15-2013, 03:03 PM
deathtrap
The small end of the rod needs to be heated. I would take it to a machine shop, shouldn't cost much to do one piston.
deathtrap is offline
post #3 of 12 Old 09-15-2013, 03:36 PM
snail81
if you can press it out yourself you can do it. they heat the rod to expand it to press it in and out easier
snail81 is offline
post #4 of 12 Old 09-15-2013, 03:46 PM
jsawduste
2006 YJ Wrangler
^^^^this^^^^
jsawduste is offline
post #5 of 12 Old 09-15-2013, 04:38 PM Thread Starter
Jimidude87
Alright so the heating thing is just to make it easier to install but is not necessary right?
post #6 of 12 Old 09-15-2013, 06:08 PM
snail81
Correct.
snail81 is offline
post #7 of 12 Old 09-15-2013, 06:36 PM
jsawduste
2006 YJ Wrangler
^^^^this^^^^
post #8 of 12 Old 09-16-2013, 03:48 AM Thread Starter
Jimidude87
You guys have any idea of how much harder it will be without the heating?
post #9 of 12 Old 09-16-2013, 04:31 PM
snail81
i dont think the arbor press will do it unless you heat the rod and maybe freeze the piston pin. when you go to put them together you better be quick about it. I used this method when installing bearings when I rebuilt my 8.8. It works great.
snail81 is offline
post #10 of 12 Old 09-16-2013, 05:48 PM
Jeepsr4me
Heat the rod end or u risk cracking piston also freeze pin with dry ice and it should drop straight in.
No need heating it to take out but helps. Cheap propane torch works great.
http://m.youtube.com/watch?v=nkChxaa...%3DnkChxaaKpYk
Jeepsr4me is offline
post #11 of 12 Old 09-16-2013, 08:15 PM
deathtrap
Yep, Why risk breaking the new piston to save 10 bucks?
post #12 of 12 Old 09-16-2013, 11:31 PM
timatoe
timatoe's Avatar
Exactly. I just rebuilt the 350 in my little motorhome, $6 ea at the machine shop. Way cheaper than new rods or pistons if I screw it up.
timatoe is online now
