ASD Switch -
post #1 of 1 Old 03-05-2012, 06:50 PM Thread Starter
ASD Switch
i have a 95 wrangler rio grande 4 cylinder.
where is the automatic shut down switch.
i have narrowed my engine problem to the ASD relay, i put a new one in it and it burned it out too. i am going to just bypass the switch all together. i just need to know where it is!!!!
fixnstuf3 is offline
In order to be able to post messages on the forums, you must first register.
Writeup on bypassing transfer case switch for CAD with manual vacuum switch dancytron YJ Wrangler Technical Forum 3 08-02-2011 07:34 PM
Using factory Defrost switch to control door switch/dome light aestrad1 TJ Wrangler Technical Forum 4 01-29-2011 07:00 PM
hey guys wondering how to wire lights to the switch by the rear wiper switch... help kingator TJ Wrangler Technical Forum 1 09-26-2010 08:00 PM
aftermarket horn wired to switch, would like stock to work on switch as well hilton00 TJ Wrangler Technical Forum 14 01-02-2010 02:11 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
