articultion yj 5 inch lift - JeepForum.com
post #1 of 4 Old 09-14-2011, 08:02 PM Thread Starter
jojojeep1
i have about 5 inchs of lift , 33 inch mtz , but i never put in the longer shocks , if i put in the longer shocks i should get greater articultion . if im wrong let me know ,if im right let me know why thanks.
jojojeep1 is offline
post #2 of 4 Old 09-14-2011, 09:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Take the shocks off and flex it out as far as it can go. Then by process of elimination, use the best shock.
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 09-14-2011, 10:48 PM
zte87
GIVE IT THE ONION
zte87's Avatar
how do you have stock legnth shocks with 5 inches of lift? that must ride like crap!
zte87 is offline
post #4 of 4 Old 09-15-2011, 02:15 AM Thread Starter
jojojeep1
it rides ok on the road / but off road when you go into a dip its a drag , i read you can go 3 inchs safely with a stock shock , but the new springs gave me over 4 indhs ,then then i used 1 1/4 boomsrangs. so that put me over the edge i'll see over the weekend thank you.
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 09:36 AM
2 inch spacer lift vs 4 inch suspension lift and Death Wobble BadKarma1701 TJ Wrangler Technical Forum 37 03-10-2011 07:00 PM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 10:16 AM
