ARB Solenoid leaking air out the top - JeepForum.com
post #1 of 14 Old 05-20-2009, 08:00 AM Thread Starter
champelite210
Air is leaking constantly out of the top of the solenoid. Is it bad? or is it just stuck open?
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #2 of 14 Old 05-20-2009, 08:07 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Have you tried cleaning and adjusting it yet?
Joe Dillard is offline
post #3 of 14 Old 05-20-2009, 09:32 AM Thread Starter
champelite210
How do you do that. It's on a used jeep we just got. I've not messed with ARB's to much
post #4 of 14 Old 05-20-2009, 09:52 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The only time mine ever 'leaked' was when it had crap inside preventing the valve from working properly. The knurled knob at the top of the black solenoid unscrews to allow the black box coil part to come off. Do that and try to see where it's leaking for sure. I recall the post the coil goes on and it's lower plate are held on with two small screws. You could unscrew the post that is left and clear the valve in side, probably has debris in there. You could also remove the in/out parts to get access to the main internal passage to clean it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 14 Old 05-20-2009, 10:06 AM Thread Starter
champelite210
Thanks. I think the valve is stuck open. It's coming out of the same port that it would if you unlocked them.
post #6 of 14 Old 05-20-2009, 10:52 AM
mark8201
1987 YJ Wrangler
Check and make sure it is installed properly if this is a new install. As I had reveresed mine a while ago and had the same issue (I reverse the air hookup, to the flapper inside the solenoid would close.) I flipped it around and was good to go.
mark8201 is offline
post #7 of 14 Old 05-20-2009, 10:58 AM Thread Starter
champelite210
It was on the jeep when we bought it. I'll check that though.
post #8 of 14 Old 02-17-2013, 02:06 PM
Jeeps4play
I'm having the same problem....... I replaced with new "air solenoid" and it still looses air through the exhaust vent screw. Did you ever find out what the problem was caused from?
Jeeps4play is offline
post #9 of 14 Old 02-17-2013, 05:28 PM
JeeperDon
JeeperDon's Avatar
If they get crap inside, the valve won't close properly. Take the output fitting off the block and you will probably see something there.
Web Admin for
post #10 of 14 Old 02-18-2013, 08:01 AM
Jeeps4play
Took off cleaned with brake cleaner spray (advised by arb) put back together and I still loose air when I enguage the rear locker through the solenoid. Front works fine. Could it be possible that the problem is in the diff? I've never had it apart so I'm not sure what it looks like... maybe an Oil ring or clogg/dirt?
post #11 of 14 Old 02-18-2013, 08:57 AM
jeepster93
jeepster93's Avatar
Dual air lockers...
To see if your locker will engage is easy...
Unplug the air hose from the solenoid going to the locker that is working and replace it with the one not working.
If it starts working-replace the solenoid.
If it don't start working, you stumped me. The diff part of the air locker leaking air(o-rings copper air tube, etc), will not leak through the supply hose but will leak through the diff vent.
jeepster93 is offline
post #12 of 14 Old 02-18-2013, 10:29 AM
JeeperDon
JeeperDon's Avatar
To be sure what is leaking, spray some windex on the suspect area. It's easy to apply and has just enough cleaner stuff in it to bubble nicely.
Web Admin for
post #13 of 14 Old 02-18-2013, 04:48 PM
Jeeps4play
Problem found in new switch. I wanna give a big thanks to help out. I've learned a lot by your comments trying to help me trouble shoot.
post #14 of 14 Old 05-20-2014, 12:52 PM
RockMonster
What was the problem? Mine is doing the same thing and I want to know what to look for when I go to fix it
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
ARB Solenoid & Pinion Seal Leaking jomax77 TJ Wrangler Technical Forum 4 03-10-2008 05:19 PM
ARB solenoid leaking oil??? kiksroks TJ Wrangler Technical Forum 4 08-18-2007 09:44 PM
my starter solenoid blew... can i simply replace the solenoid? hmk_21 YJ Wrangler Technical Forum 11 08-30-2006 12:34 PM
ARB solenoid leaking diff fluid Los TJ Wrangler Technical Forum 5 01-26-2005 10:51 PM
95 not starting - clutch leaking at transmission - starter and solenoid good Rusting Bucket YJ Wrangler Technical Forum 4 08-24-2004 09:15 AM
