April YJOTM Vote Now!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > April YJOTM Vote Now!!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
View Poll Results: Pick A Winner
Mudcrawler90 18 10.23%
Idso 11 6.25%
Liftedyj91 34 19.32%
scary-animal 26 14.77%
bigdhamyj 7 3.98%
'92 vegas yj 62 35.23%
youngjeepr 7 3.98%
IPOOD 4 2.27%
alex100 3 1.70%
AmmitOsiris 4 2.27%
Voters: 176. You may not vote on this poll
Closed Thread
Unread 04-21-2012, 01:41 PM   #1
Anticanman
Anticanman's Avatar
Post When You Vote!!!
Lets get some votes in this month!!!
Rules for voting:
Post when you vote please!
No solicitation of votes from within JF or outside JF
No promotion within this thread will be permitted via pictures. We have PM's, please use them
All voters will remain public as to self moderate
Here are your contestants in no particular order:
Mudcrawler90
1990 Jeep Wangler YJ
Lift:
spring over and 1” shackles
Drivetrain:
4.2L I6 with Weber carb
AX-15 5 speed
NP 231 with Slip yoke eliminator and CV shaft
Armor:
Custom ¼” steel Front bumper
Smittybilt XRC rocker guards
Gen-Right short corner guard
Axles:
HP Dana 30 front with JB 4x4 high steer bracket and lock rite
Ford 8.8 rear with limited slip and disk breaks
4.10 gears
Electronics:
CB Radio
Sony Xplod head unit
Digital gauges in an Auto Meter center gauge cluster
55 watt fog lights on custom bumper mount
ProComp 100 watt lights on the hinges
Other odds and ends:
32" BFG Mud Terrains on Pro Comp Rock Crawler Wheels
1999 TJ roll Cage w/ sound bar and custom rear hoop
Raptor Lined tub
POR-15 on the entire undercarriage (frame, axles, springs, etc.)
Custom made flip-up license plate/light/camera mount.
Sway bar disconnects (because I’m not the only person who will ever drive this and the others can’t handle the body roll)
1” Daystar body lift
Plenty of custom pin striping thanks to tight NE Ohio/Western PA trails.
ldso
1995
2.5L I4, AX5 5-speed, NP231, Harbor Freight 8000lb winch and plate, custom front bumper with flat tow brackets, 4" Rough Country lift springs/shocks/drop Pitman arm/front swaybar extensions, 2" body lift, Currie 5/8" boomerang shackles, Rugged Ridge tube sliders, Smittybilt Rock Crawler rear bumper, HP Dana 30 front axle with USA gear 4.88's, TJ shafts, Spicer u-joints and bearings, CAD delete with custom blockoff plate, JK non-Rubicon Dana 44 rear axle with new Mopar brakes, USA gear 4.88's, Yukon bearings, Detroit Locker Soflocker carrier, tubes welded, MORE spring perches and shock tabs, Teraflex rear shock bar mount system, Teraflex rear pinion yoke, rebuilt driveshafts, Bestop Trailmax II Pro Seats, Palomar CB, Moog front brake caliper and Pitman balljoint, eBay 5on4.5->5on5 1.75" spacer adapters for front axle, stock JK 16x7 steel rims, Mastercraft Courser CT 285/75x16 tires, new windshield and frame, starter, 20 gallon gas tank mod, replaced most allen bolts with hex, no track bars.
I was into import cars and a real nice old lady t-boned my 1988 Audi Quattro and banana'd the chassis. I bought the YJ bone stock in 2009. I started wheeling it in 2010 on 34" Swampers and a 4" lift and have been enjoying it since. In the last month I have just finished a total rebuild of the front axle and swapped in the Dana 44, so I only have the one dirty picture from last weekends Ohio4x4 club ride of the current setup.
liftedyj91
1991 YJ
Drive Train- Small Block Chevy 355, mild cam, edlebrock 600cfm 4bl carb. Ax 15, NP231 rebuilt Sye, both double cv drive shafts.
Axles- Front HP Dana 30 4:88's posi lock with aussie. Rear: Ford 8.8 Trussed, Aussie, 4:88's 31 spline shafts, disc brakes.
Interior- Monstalined, Racing bucket seats, Autometer gauges, RCI 2161a 15 gal fuel cell frenched in floor behind rear seat. Pioneer stereo. Custom home brew roll cage, tube fenders, ft and rr bumpers.
Bought the jeep at 18, wheeled it and got addicticted. Started doing mods and getting familier with it. Moved out to the east coast, swapped in 8.8 gears, lockers ect and rocked it for about 3k miles. bought a welder.. found frame rot in Oct 11' took it down to the frame and restored it. Original tub was trash, found a decent one and fixed it. fixed all the rust on the frame. swapped in sbc 355 ax15 np231 combo. Stretched the rear 6'' wb 100" total. just got it running about a week ago and been fine tuning it, havent drove it yet but it sounds mean! still have finishing touches to do. thanks for the opportunity
Beginning resto-
During-
after:
Scary-Animal
Year: 1987
Engine 4.2 nuttered w/ 2100 motocraft
Procomp 15x10" satin black wheels
37/12.5 Super Swamper IROKs
High Flow Cat Super 44 Series Flowmaster
AX-15 & NP 231 with SYE
8.8 Rear 4.88 Motive Ring Pinion Aussie Locker, SOLID dif cover welded tubes
Shortened Dana44 Powertrax locker, skidded,
Crossover steering, Ford knuckle, BTF steering arm
Chromoly custom front shafts shortened upgraded u joints
Modded XJ Front Shaft on rear
Custom Triangular front drive shaft built locally
Custom Fuel Tank Skid 3/16 steel plating.
Relocated Reverse shackle 1" lift rear 1" stretch.
Reverse shackle stock length front shackles
Front stretch 2" with WP Warrior Cross-member/mounts
3.5" BDS Springs SOA
Bedlined inside and out
Rancho 9000
2002 Grand Prix Seats
2007 Durango Center Console
Highlift Jack mount made from All-Thread, stock spare tire bumpers
9 in over stock extended steel brake lines
Durango steering gear box
Smittybuilt SRC Front Bumper (slightly modified)
200W Kenwood Amp Hooked to 2 Alpine 4.5" dual plate Mids/Tweets & 2 Premire 6x9s
4.5" LED taillights with 1.5" Halogen reverse/rock lights.
Custom Tube Fenders/Stock inner fenders modified
Antiwrap cables with turnbuckle and locks
Bought this Jeep as a stocker from my father-in-law. I decided I wanted to learn about vehicles, and weld, and fabricate metal... so I taught myself via my YJ.
bigdhamYJ
My YJ is a 1993 with the 2.5, ax-5, and 231. Pretty standard setup, she's got 3.5" Skyjacker Springs, Stock length Boomerang Shackles from VACJ5, quick disconnects, SYE, 33x10.5x15 KM2's, ARB Snorkel, TJ flares in the rear, 19lb/hr Ford 5.0 Injectors, VACJ5 CB antenna mount, cobra dx19, best top trail max front seats, and a rampage center console. And here's a list of what I've got waiting to go on... 8.8 w/discs and 4.10's, JB4x4 High Steer bracket, extended brake lines, an e-fan set up and 4" flush mount LED tail lights. My plans are to have it setup and SOA with the 8.8 by May running an Aussie in the rear and 4.88's front and rear, possibly on 35"s again (I say again because it was on 35's when I first got it), and eventually buy a frameless soft top! It's my pavement pounder, I absolutely love it, and cannot wait to continue building her up! Thanks for keeping this contest going!
Luck favors the prepared
Originally Posted by squarelight94 View Post
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
Originally Posted by jbolty View Post
I would like to thank everyone who thanked Anticanman.
Originally Posted by egodfrey
Well canada is a different story this is american talk here silly :rofl:
Anticanman is offline
Unread 04-21-2012, 01:44 PM   #2
Anticanman
Anticanman's Avatar
'92 vegas YJ
-'92 YJ
-4.0L with airaid air intake
-AX15
-NP231 w/ true nuetral plate and Advance Adapters SYE
-97 1/2" Wheelbase
-SOA front with waggy springs plus offset perches for a 3" front stretch
-SOA rear with bastard pack springs made up of stock and some procomp lift springs to help keep some arch
-1/2" BESRK boomerang shackles F/R
-Bilstien modified front TJ shocks
-Doetsch Tech rear shocks
-D30 front axle with vacuum CAD delete running TJ shafts
-Spartan locker
-SOLID diff cover
-Ford 8.8 rear axle w/ disk brakes
-SOLID diff cover
-35x12.50r15 Goodyear MTR(not pictured)
-15x8 cragar black steel wheels
-custom shortened "stubby" front procomp bumper
-Rear Smittybilt bumper tire carrier w/ fullsize spare
-M.O.R.E. hi-steer bracket with custom drag link & Tie rod
-Tatton front Drive shaft that allows for stretch
-Poison Spyder aluminum crusher corners
-4 1/2" LED tail lights
-Warn m8000
-A/C converted to OBA w/ 3 gallon tank mounted in trunk area
-Herculined interior
-Sony CD player/radio
-Sony 6x9 speakers mounted on rear wheelwells
-VDP center console
-instatrunk
-TJ rear flares
-GT Grant steering wheel
-roll cage mounted fire extinguisher
-rear parts box for spare parts, tools and first aid kit
-Hi-lift jack
_daystar interior switches for accessories
-Flowmaster exhaust beat up from trails
-body damage
DIY parts made solely by me
-Tube fenders using stock inner fenders w/ Genright mesh side louvers
-rocker guards
-oil pan skid
-traction bar made from 1.5x.250 DOM with ruffstuff heims and poly bushings
-traction bar mount and custom made shackle
-steering using 1.5x.250 DOM w/ Ruffstuff 5/8 hiems
-front and rear sport cage from 1.75x.120 DOM
-Cut down XJ shaft for rear CV shaft using 3"x.250 4130 Chromolly(made w/ the help of Joe Dillard)
-Steering box brace
-license plate relocation mount
Youngjeepr
1988 YJ
MOD list:
1999 crate 350
mild cam
Edelbrock intake
TH400
NP231
Dana 30
Chromoly TJ shafts
Powertrax no slip locker
Ford 8.8 rear
SOA on stock springs. Soon to be XJ springs
Warn M8000
Hurculined tub
Homebrew sliders
Homebrew front bumper soon to be replaced with another homebrew.
When I was 14 I thought jeeps looked cool so I got a job and started saving up for one. By the time I was 15 I bought my 88 yj with 128k completely stock. I knew absolutely nothing about cars, but I thought it looked good so I didnt care about the mechanical condition about 6 months later the clutch went out so I bought a repair manual and taught myself how to do it. After that all hell broke loose and I was constantly working on it... Long story short I have now replaced every part on my jeep besides the body and frame. Now that im 19 I have my jeep just about where I want it, until I go 4 link and full width axles.
when I first bought it
Just after I finished SOA and 8.8 swap
Most recent picture
IPOOD
1994 Jeep Wrangler S
4cyl, 5spd, 4X4.
Minimalist Build:
Home brew shackle lift 2"
painted frame, painted front bumper and brush bar, removed bumperettes, replaced old torn black top and upper doors with perfect condition donated tan top and upper doors, moderate stereo install, Cobra 25, 100w HF off road lights, rear LED lights, Clear tractor trailer marker lights for reverse indicators, Recently locked front axle pod, Home brew hitch receiver, Home brew mirror brackets, JK front and rear seat covers, Half bikini, Full bikini, CRES, Duster, Touch screen switches, and Sierra Nevada tap for the transfer case. More to come just doing this on a family mans budget. [/IMG] [IMG]
alex100
1995 jeep wrangler 4.0 HO
3.5 in black diamond lift
1 shackle lift
home made snorkel
12,000 lb badlands winch
31x10.5 BFGoodrich all terrains
craiger steelies
brush guard
home made rocker guards
kenwood 200 watt head unit
bedlined interior
6x9" speaker pods
tj flair cut outs in back
some other work...
rust reapair, new skid plate, new floor pan
I got my jeep when i was 17 simple because I thought it was cool. Then I started to fall in love with it. Now I spend all my time and money with my friends in the garage working on it and learning about it. Its slow work but I have had a blast trying to get it ready to do some wheeling over the summer.
AmmitOsiris
My CANADIAN 1990 blue/grey jeep wrangler YJ made in April of 1990
All Stock for now, have 2.5 OME Springs on , P235/75/15 PEGASUS ADVANTA A/T's on Black Steelies, Has Stock gray HardTop, the very sexy old school style rollbar, 5 Speed AX15, NP 231, D30, D35, 3.07 gear ratio, max speed of 80 MPH!!!!..... only if it was 88 MPH then i could time travel......
well hi im JAKE...or as somebody else says it.. "Jake The Snake".... my jeep and i came into contact 5 years before i got her, she was in a field where we got our retarded cats at and i was like thats what i want for my first car, well skip forward 4 years... my mom had asked the owner of the land if we can keep some 4H animals on there property and they said yes and i was always around it always sitting in it and just inspecting it, well a year later on March 17th 2011(16th birthday) my parents bought it for me and surprised me with it, and we've been together ever since, but then the horrible happened i got into an accident on February 03rd 2012 (brakes failed) and i ruined the whole driver side front clip of it but i got her fixed up for the most part... and im driving her. we got some OME 36 R springs on her now and have a procomp bumper thing on it that i got from J&W jeep wreckers for a whopping $30!!!!
Also SPRINGER stands for how i got her in the spring and fixed her in the spring and how i have no shocks just straight springs for now..
1 week after the accident
how she sits well sorta, no recent pics of puddle dashing but here she is
Unread 04-21-2012, 01:52 PM   #3
Anticanman
Anticanman's Avatar
I'd like to thank our anonymous judges this month. And I would like to thank our sponsor: Metalcloak!
Unread 04-21-2012, 01:56 PM   #4
TSEJEEPERS
Some great looking Jeeps again this month!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline
Unread 04-21-2012, 02:05 PM   #5
Anticanman
Anticanman's Avatar
Go vote for the tj's too
http://www.jeepforum.com/forum/f9/ap...14/index4.html
Unread 04-21-2012, 02:05 PM   #6
AmmitOsiris
very good selection of YJ'S but anyways
voted
[color="navy"][B][U][URL="http://www.jeepforum.com/forum/f22/highschoolers-build-thread-springer-1352289/"]look at my plain lookin' build thread[/URL][/U][/B][/color]
[CENTER][B][U]JAKE "The Snake"[/U][/B][/CENTER]
[B][U]"SPRINGER" [COLOR="Navy"]1990 4.2L YJ[/COLOR],[COLOR="Navy"]BLUE[/COLOR],[COLOR="Gray"]GRAY hardtop[/COLOR], 2" O.M.E lift, P235/75/15 Pegasus Advanta A/T, with Black Steelies D windowed,[/U][/B]
[QUOTE=Anticanman;14153277][B]If you don't like it you can always take it through the car wash to erase it like an etch-a-sketch[/B][/QUOTE]
[QUOTE="Anticanman"][B]The grass is always greener on the other side of the fence. Especially when that grass is being use by coeds to play volleyball in bikini tops... :drool:[/B][/QUOTE]
AmmitOsiris is offline
Unread 04-21-2012, 02:08 PM   #7
mudcrawler90
Great selection this month, I narrowed it down to a few but Scary Animal got my vote again this month. I'm a little partial to spring overs and 4.2s.
Having to tow your Jeep down the road with a stock truck is like water skiing naked, its embarrassing, your being pulled by a single line, and it hurts a little but in the end all you can do is look back on it and laugh!
/l , [____],
l------L--[]lllllll[]-_
()_) ()_)==♠=)_)
mudcrawler90 is offline
Unread 04-21-2012, 02:09 PM   #8
jeepinmichguy_
No longer a Jerk....
jeepinmichguy_'s Avatar
Yup, I voted.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline
Unread 04-21-2012, 02:18 PM   #9
youngjeepr
youngjeepr's Avatar
there are some great looking jeeps this month! Good luck to you all
88 YJ- 99 crate 5.7l, SOA, 8.8, hp D30 powertrax no slip, stock replacement springs, 35/12.5 r15 goodyear kevlars
Utah Jeep Crew
JUNE YJ OF THE MONTH!
Build Thread
youngjeepr is offline
Unread 04-21-2012, 02:35 PM   #10
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Voted.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build
My Mods
My YouTube Channel
Jeffro06 is online now
Unread 04-21-2012, 02:44 PM   #11
roadyrob
1987 YJ Wrangler
i'm in
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
Unread 04-21-2012, 03:02 PM   #12
cs1094
voted liftedyj91. I like all the work done and the frame-off is nice.
1999 TJ Sahara, 33X10.5 BFG's, 3" lift, Smittybuilt XRC8 winch, Discos
cs1094 is offline
Unread 04-21-2012, 03:25 PM   #13
mrmark
mrmark's Avatar
Voted, and there is a much more even playing field this time, there isn't one has done extensive off road mods like some in some past months to make it really stand out
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
Unread 04-21-2012, 03:44 PM   #14
dillonjm
Blimps are terrible...
dillonjm's Avatar
Nice rigs, gents.
Went with Vegas.
01 WJ Limited - 4.7L - Current build here
08 Dodge 2500 Laramie(DD/Tow Rig): Cummins 6.7L/G56 6spd, Deletes, Smarty, SBDD3250, 3.5" / 285 75/18 Toyo AT2s / B&W Gooseneck
05 Liberty Limited (Wife's): 3.7/Auto, OME + Clevis + Rear Iso's, JBA upper arms, 245 70/17 Duratracs w/stock 17" Limited wheels and 1.25" spacers.
dillonjm is online now
Unread 04-21-2012, 04:39 PM   #15
BabyYJ
Voted. Nice rigs, everyone!
BabyYJ is offline
Closed Thread
