Anything electrical "blips" while Jeep is on. - JeepForum.com
post #1 of 10 Old 12-22-2014, 09:20 AM Thread Starter
BigJ367
Hey everyone, for some reason anything electrical. (All lights, radio, fan, AC) will "blip" or turn off and on. Its hardly noticeable with the lights, they just dim for a split second then they are back up. Only way I noticed was the radio kept turning off and the heater/vent fan would hesitate for a split second. It happens when I'm both stopped and driving. I'm guessing its a ground. Would it be the main ground from the battery? That one seems to be in good shape. Thanks a mil!
BigJ367 is offline
post #2 of 10 Old 12-22-2014, 09:26 AM
cwein23
Does it happen when the engine is off and the electricity is on, or just when the engine is running?
cwein23 is offline
post #3 of 10 Old 12-22-2014, 09:34 AM Thread Starter
BigJ367
It does it when the engine is off and when it is running.
BigJ367 is offline
post #4 of 10 Old 12-22-2014, 09:52 AM
bharris68
Daily Driver
Sounds very much like a bad ground / battery connection broken internally.
Pictures of the area around the battery cables? Check the engine ground from the battery and check all your terminals and such as well. If you have an electrical meter you can check resistance - higher resistance or moving to infinite as you shake or jiggle the leads will show you which one (if either) is bad.
bharris68 is offline
post #5 of 10 Old 12-23-2014, 10:15 AM Thread Starter
BigJ367
Sorry for the delay in replying. Attached are some pics of the ground cable. I am going to replace the cable and terminal as well as clean up around the ground mount on the motor. I'll let yall know how it goes.
BigJ367 is offline
post #6 of 10 Old 12-23-2014, 10:30 AM
cwein23
Any luck with it? If you negative terminal is corroded it wouldnt be a bad idea to check the positive one either
cwein23 is offline
post #7 of 10 Old 12-23-2014, 10:48 AM Thread Starter
BigJ367
Both terminals seem to be in great shape. Either way I will replace the negative one just in case its cracked. I am going to try and work on it tonight once I get home from work.
BigJ367 is offline
post #8 of 10 Old 12-23-2014, 02:48 PM
dancytron
While you are at it, follow the small positive battery cable. You'll see that it goes to a post on a little box on the firewall. This is the Starter Relay (among other things, but it is called the Starter Relay).
On that post is the small positive battery cable and 5 or so 10 gauge wires that start with fusible links. All of the power for the whole jeep goes through here except for the main power to the starter.
Unhook the negative battery terminal. Then, undo the nut and clean up everything on that post until it is nice and shiny. Make sure that all the wires on that terminal look to be in good shape.
dancytron is offline
post #9 of 10 Old 12-25-2014, 06:30 PM
bergovoy
the ground should go to the motor and to the frame/chassis...
the ground from the motor to the chassis is usually a braided flat cable...
i would spray baking soda and water, librally all over the connection points.. if there is oil or residue, then clean that off first... then clean with the baking soda mixture.
after it is dry, you can coat the connection with Vaseline or battery terminal protectant...
also as stated above. check the red wire to the power distribution box, either next to the battery or under the dash near next to the fuse block...
check the main fuse, and grease the connectins with dielectric grease...
other then that, you may have a short and it is only shorting very sporadicly... good luck
bergovoy is offline
post #10 of 10 Old 04-11-2015, 10:38 PM
Fyrbudd
Obviously this thread is a bit old, but I just chased a similar problem down in my '92 YJ. Perhaps this will help someone, just in case it wasn't the grounding demon.
My heater fan went out, my wipers would work only on "Mist" but then failed altogether. The real pain came when the Jeep suddenly refused to start. It turned over strongly but would not fire. I had no power to the ASD relay coil or to the fuel pump relay coil. It turned out to be the ignition switch, which controls power to all three of these functions. As these vehicles age the grease dries up and parts wear. Inside the lock cylinder for the ignition this can result in a "lazy" return from the "Start" position, leaving a high-resistance condition between two or more of the ignition switch contacts. The heat causes the solder to melt and the contacts to arc and carbonize. Since nearly all sub-systems are controlled by the ignition switch it can cause demons in any of those electrical systems. Your fuses will all be good and you will spend a great deal of time hunting this down. Try wiggling the key cylinder and checking out how it rolls back from Start to On. If it duplicates or cures the "on again, off again" problem you will have your answer. If not, then you have ruled it out. There is an excellent posting on this forum by Opihi59 regarding the removal and replacement of the switch elsewhere in this YJ technical forum. If you do replace the ignition switch be sure to service the lock cylinder to prevent another failure.
So many people, believing so many absolute, but conflicting truths, cannot possibly all be right.
Fyrbudd is offline
