Anything to compensate for power loss with bigger tires, besides regearing? - JeepForum.com
post #1 of 17 Old 04-05-2013, 08:28 PM Thread Starter
Campsen
I'm finally picking up new tires (33x10.5x15) and putting on a 4 inch lift on my 93 4cyl with stock gears and axles. I don't think I want to regear because it sounds like too much work, and I'm wondering if there's any alternative to make up for the power loss. Chances are I'm going to lose the use of 5th gear. Please let me know if there's anything I can do without putting too much labor/cost into it.
Campsen is offline
post #2 of 17 Old 04-05-2013, 08:31 PM
SeanB95YJ
short answer = no
go back to smaller tires, regear or engine swap
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 17 Old 04-05-2013, 09:06 PM
gunshw301
Besides the correct answer above you could ditch weight.
Toss....windshield, seats (use a light weight race seat for driver or a milk crate), spare tire, toss the front and rear bumpers, remove the skid plate replace with a skid bar, cut holes and dimple die the frame. Remove front and rear track bars, steering stabilizer, sway bar. Remove the gas tank skid and replace with strap steel or twine if your cheap. Lower the spring lift to 2.5 inch lift, cut body to allow for tire size. Replace roll bar with a chromoly roll bar, or live dangerous and use aluminum. Replace hood with a lexan version. Mold a new light weight grill out of carbon fiber. Throw out the dash and just zip tie and glue gauges in place or toss gauges you don't need them. Only put 3 gallons of gas in the tank at a time. Replace the gas gauge, you will need that. Toss the tail gate, no need for one because there is nothing to keep in, might as well toss the doors as well. Replace the headlights and tail lights with stickers and only run during the day (keep lights for easy replacement during inspection).
So yeah, simple answer is not really, not so simple answer was kinda fun though.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #4 of 17 Old 04-05-2013, 11:54 PM
gtg413i
2003 WJ
I got the most weight savings by replacing the air in my tires with nitrogen.
Brian's Black Betty Build:
gtg413i is offline
post #5 of 17 Old 04-06-2013, 12:38 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Point yourself downhill.
Luck Favours The Prepared
Anticanman is offline
post #6 of 17 Old 04-06-2013, 02:44 AM
Mark05059
add more cyls
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 17 Old 04-06-2013, 07:21 AM
superj
Engine swap is the most fun for the money though. V8 wrangler is a head turner just be aide of the exhaust sound
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 17 Old 04-06-2013, 07:27 AM
soonermatt
Haha. On certain days and directions I've felt like a sail could really help.
soonermatt is offline
post #9 of 17 Old 04-06-2013, 07:38 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You don't have a soft top? That's pretty much a sail, right?
post #10 of 17 Old 04-06-2013, 07:42 AM
flea1987
Originally Posted by SeanB95YJ View Post
short answer = no
Give up a few inches of tire is probably your best bet
flea1987 is offline
post #11 of 17 Old 04-06-2013, 08:23 AM
bogleparsons
Originally Posted by flea1987 View Post
give up a few inches of tire is probably your best bet
never!!!
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #12 of 17 Old 04-06-2013, 08:44 AM
msprooch
Even removing weight the jeep will still be sluggish. The problem you are facing is the distance travelled per driveshaft rotation. I drove my jeep with the stock gears for 1.5 years before I regeared it, and I was so happy with the results.
msprooch is offline
post #13 of 17 Old 04-06-2013, 10:51 AM Thread Starter
Campsen
... I think regearing would be a little easier than doing all of this.
Campsen is offline
post #14 of 17 Old 04-06-2013, 10:53 AM Thread Starter
Campsen
I think regearing would be a bit easier than doing all of this...
Campsen is offline
post #15 of 17 Old 04-06-2013, 10:54 AM Thread Starter
Campsen
didn't mean to quote the first guy^^ don't know how to delete it either..
Campsen is offline
