Anything better than POR15? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Anything better than POR15?
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 06-17-2010, 07:12 AM   #1
tonythehazelnut
I'm looking to seal my new used frame for my YJ build, but I'm not sure what to use. Any ideas? Is there anything better than POR15?
Built Not Bought #482
LEGALIZE ILLINOIS CONCEALED CARRY
AN ARMED SOCIETY IS A POLITE SOCIETY
tonythehazelnut is offline   Reply With Quote
Unread 06-17-2010, 08:05 AM   #2
dan240
Powder coating will be tougher but POR15 can be touched up at home in the garage.
Also, the POR15 you will be able to run inside the frame rails. I don't believe you'll be able to powder coat the inside of a frame.
5 years ago we powder coated a frame for a build. It still looks great and has held up well. It was a YJ frame that doesn't rust like a CJ frame. We're also in SoCal so rust is not such a concern.
Dan
1994 YJ 4.0L 5spd
SOA, TJ Flares, 33" BFG MTs, Ford 8.8, SYE/CV
dan240 is offline   Reply With Quote
Unread 06-17-2010, 08:10 AM   #3
samsonitesamson
Chasis Saver
They say it's better the POR15, it's cheaper, and you get JF discount!
Monstaliner do-it-yourself roll-on truck bed liner
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline   Reply With Quote
Unread 06-17-2010, 08:20 AM   #4
wrangler76
I would powdercoat and save the POR15 for areas or rust repair. I'm appreciating the realtively rust free NW more and more though with the rain and 60 deg weather I'm missing the summer!!! Is it April still????
wrangler76 is offline   Reply With Quote
Unread 06-17-2010, 08:23 AM   #5
Goobersbro
Originally Posted by samsonitesamson View Post
Chasis Saver
I've talked to some local paint shops and a paint dealership and they have all told me to stick to the POR and most of the shops carry both brands they told me if I was going to order it. POR would be better its been around longer and has a better reputation they said they have had customers come back after buying chassis saver and buy POR
My marshmallow build
http://www.jeepforum.com/forum/f12/m...-build-873442/
Goobersbro is offline   Reply With Quote
Unread 06-17-2010, 08:40 AM   #6
monkeyhouse
Don't listen to that crap, chassis saver is by far a much better product. See for yourself, go here and talk to jeep forum members who have used it or even better talk to magnet man!
http://www.jeepforum.com/forum/f43/i...-liner-875162/
From that thread:
We are also the manufacturers of Chassis Saver™ Rust Preventive Truck & Auto Underbody Coating.
Chassis Saver is a high performance alternate to POR-15 at 45% lower cost.
From the chassis saver web site:
“Oh by the way I have bought a gallon of your Chassis Saver
before for my race car, and I have to say that stuff is
awesome. Very high quality product for a very good price.
Sure beats POR-15!!!" — L.M., Woretown, NJ
"I have waited before saying anything about your Chassis Saver
product until I had a chance to try both your product and the
competition. I am very satisfied with the finish and durability.
The restoration I completed 3 years ago looks as if it was done
a few months ago. Your product is by far the most durable and
provides excellent coverage. Chassis Saver is really
awesome paint, it beats the finish of POR-15 hands down."
— J.C., Colorado Springs, CO
BTW, if anybody used chassis saver and went back to por-15, they didn't follow the directions and definitely never talked to magnet man. Chassis saver is a much better product.
1989 YJ, 6 cylinder 4.2L , 258. replaced cooling system, Nuttered and TeamRushed, Weber 38 DGES, Thanks to S.R. Wilson, Sr. for GIVING me a skid plate!
monkeyhouse is offline   Reply With Quote
Unread 06-17-2010, 03:05 PM   #7
gunnorthered
I have used both. POR-15 on the frame and Chassis Saver on the tub. For POR-15 I'd have to say that if you plan on a top coat to make sure it's done in the recommended time frame and not days after. Nothing seems to stick to it even when I used 320 grit paper. Chassis Saver top coats easily after the 320 grit paper was used. Otherwise I haven't seen too much of a difference with them, especially since the vehicle they were applied to doesn't move yet.
As far as powder coating goes. I would only bother with that if you don't go offroading. I was told by a powder coating place that it's tough to repair a good paint job, and why spend all the money just to scrape it off on the rocks.
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P.
1993 YJ - Stock 2.5L, Scrapped. R.I.P.
[URL="http://www.jeepforum.com/forum/f12/desert-rat-build-830626/"]1994 YJ - Stock 4.0L, Currently getting the frame off treatment and being built up.[/URL]
gunnorthered is offline   Reply With Quote
Unread 06-17-2010, 03:14 PM   #8
bluexj
I haven't used POR-15 but look into KBS coatings. I haven't used it yet but I have some in the garage and will be using it on my axles and frame soon.
bluexj is offline   Reply With Quote
Unread 06-17-2010, 05:48 PM   #9
plym49
POR will only be effective if the frame has no existing paint or primer AND has a surface coating of rust.
It is the rust (not loose rust or scale, surface rust) that lets POR do its thing. POR cures by exposure to moisture. It binds to the rusty metal because it pulls the moisture out of the metal. This, coupled with the impermeable hardening, prevents further rusting because the old water is away from the metal and the new water can't get in.
If you have paint on the frame POR is a waste of money because then it cannot do its thing. If the chassis is rust free, like sandblasted for instance, the POR will not be as effective (you would be better off letting it rust a bit first). ALso, POR is ineffective over any oil or grease.
For all of these reasons POR may or may not be correct for you. That is for you to decide.
Powder coating is also not the best for a Jeep. IMO. It is brittle. If the powder coating application is not perfect, you can get rust formed between the outer powder coat (which continues to look good) and the metal.
I do not have any experience with Chassis Saver, so cannot comment on that.
For an item as large as a frame, you might be best off with a durable primer and paint combo. It can be touched up. If you keep the frame clean (including the insides) it will not rust again.
plym49 is offline   Reply With Quote
