To anyone who has replaced a fuel pump. - Page 3 - JeepForum.com
post #31 of 32 Old 02-25-2009, 12:54 PM
Old4X
1990 CJ7
Originally Posted by Levinz11 View Post
So by installing an inline pump, the old one simply stays in the tank??
Folks do that, but it is best to remove the old pump. BTW you see this often on used car lots (and you can bet they didn't drop the tank).
Old4X is offline
post #32 of 32 Old 02-25-2009, 03:40 PM
heep1991
Could you explain this a lil better? Remove cap from fuse and push fuse together???
Yea sorry its called a relay. Take cover off relay for fuel pump and you will see a metal tab that is not quite touching the unit and all you do is squeeze the relay together allowing that piece of metal to touch unit. This will turn on the fuel pump. It will allow you to run fuel pump manually.
1991 YJ 2.5L - SOLD
2006 Jeep Commander 6cyl - SOLD
2007 Jeep Unlimited Rubicon 3.8L
heep1991 is offline
replaced relays but Fuel Pump still doesn't prime lexinator02 YJ Wrangler Technical Forum 10 12-28-2009 11:29 AM
Fuel Pump Replaced- Now gas odor??? cmedeiros17 YJ Wrangler Technical Forum 6 10-14-2009 01:08 PM
Replaced fuel pump assembly... Jim Shanks TJ Wrangler Technical Forum 1 11-09-2004 12:04 PM
Replaced fuel pump & no gas to fuel rail Part 2 BrianBC YJ Wrangler Technical Forum 0 08-24-2004 08:20 AM
Replaced fuel pump & no gas to fuel rail BrianBC YJ Wrangler Technical Forum 11 08-22-2004 11:41 PM
