To anyone who has replaced a fuel pump. - Page 2 - JeepForum.com
post #16 of 32 Old 02-24-2009, 10:20 AM Thread Starter
Levinz11
Originally Posted by rustywrangler View Post
Well then I guess the pump or connections at the pump are the next step. Sorry, was just trying to troubleshoot abit for ya.
Thats all I was looking for.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #17 of 32 Old 02-24-2009, 10:48 AM
azgurney
When you say your fuel guage does not work do you mean it stays at empty or full? If it stays pegged out on full then you have a bad ground to the fuel pump and guage. They both use the same ground connected at the parking brake pedal mount bolt.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #18 of 32 Old 02-24-2009, 10:50 AM Thread Starter
Levinz11
It stays at empty. Sometimes swinging over to 1/4 or 1/2 but never farther.
What does that mean? I always thought the sending unit was bad.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #19 of 32 Old 02-24-2009, 10:56 AM
veritas4156
1991 MJ Comanche
The sending unit uses a serious of strips of metal to ground the tank at different spots which put out different resistances, and something technical like that, blah blah blah, but what he was saying was that it still could have been a wiring issue but judging by your post it doesn't seem like it.
Just so you guys know, I don't really know how a sending unit works but that makes sense^^.
veritas4156 is offline
post #20 of 32 Old 02-24-2009, 10:58 AM
heep1991
Just a thought before dropping witch I have delt with and continue to deal with. I have 91 jeep and the fuel pump had a bad ground. I found this by using multimeter on the fuel pump plug witch you can access without dropping. Test both sides of the plug, I have to attach wire from plug that comes from fuel pump and ground it to my bumper. I will post pictures today of setup. Standby
1991 YJ 2.5L - SOLD
2006 Jeep Commander 6cyl - SOLD
2007 Jeep Unlimited Rubicon 3.8L
heep1991 is offline
post #21 of 32 Old 02-24-2009, 11:04 AM
jeepster93
jeepster93's Avatar
I got the NAPA pump. It was about twice the size of the Bosch one.
When you have the tank dropped, get the sender working then.
Do you have a dent in the skid plate cover over the gas tank? That could cause the sender to get stuck on that baffle that is in the tank.
Here is a pic of my fuel pump/sender unit...
The actual "pump" is that aluminum looking cylinder. But what I got included in the box was all the parts it takes to remount the new pump into that harness it is in.
Here you can see the bulge in the baffle that is down inside the gas tank. Caused by a dent in the skid plate. It caused my sender to not work.
jeepster93 is offline
post #22 of 32 Old 02-24-2009, 11:13 AM
fratis
fratis's Avatar
the above is a fairly common problem. this happened to me and over time messed everything up. ive done 2 pump replacements and never had a pump that was an identical match to the factory. always a bit of finagling to make it work. these were the ones napa had for my application a 91.
fratis is offline
post #23 of 32 Old 02-24-2009, 11:52 AM Thread Starter
Levinz11
How did you get to those without dropping the tank. Any pics would be great!
PLEASE DEPOSIT $.75
Levinz11 is offline
post #24 of 32 Old 02-24-2009, 12:17 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The plug pigtail should be accessable up infront of the tank. It is tight up there but doable from a creaper.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #25 of 32 Old 02-24-2009, 12:50 PM Thread Starter
Levinz11
As soon as the boos leaves I'm heading out there to check these things out. Ground at the emergency brake bracket. Pigtail in front of tank. I didn't see it yesterday, but I'll look again.
Thanks again guys!
PLEASE DEPOSIT $.75
Levinz11 is offline
post #26 of 32 Old 02-24-2009, 05:51 PM
heep1991
Wire is long enough to reach tire well.
as you can see I removed insulation on ground wire and attached wire to ground to rear bumper.
wire running from fuel pump plug to bumper
Hope this helps dropping tank is pain. I've done it many times though
1991 YJ 2.5L - SOLD
heep1991 is offline
post #27 of 32 Old 02-24-2009, 05:52 PM
heep1991
Below is great way to test fuel pump and also get fuel to engine quick if you run outa gas or just need to fill lines. Remove cap from fuse and press the fuse together. Fuse is always power and you dont need key in or anything. FYI you can do this with all fuses.. to think about it probley do starter and fuel pump at same time and maybe start Jeep lol.
1991 YJ 2.5L - SOLD
heep1991 is offline
post #28 of 32 Old 02-24-2009, 07:43 PM
Old4X
1990 CJ7
Carter sells an inline pump that would work. I dispise dropping a tank to fix a FI fuel pump that goes out every 60,000 miles.
Old4X is offline
post #29 of 32 Old 02-25-2009, 09:34 AM Thread Starter
Levinz11
Could you explain this a lil better? Remove cap from fuse and push fuse together???
PLEASE DEPOSIT $.75
Levinz11 is offline
post #30 of 32 Old 02-25-2009, 09:36 AM Thread Starter
Levinz11
So by installing an inline pump, the old one simply stays in the tank??
PLEASE DEPOSIT $.75
Levinz11 is offline
replaced relays but Fuel Pump still doesn't prime lexinator02 YJ Wrangler Technical Forum 10 12-28-2009 10:29 AM
Fuel Pump Replaced- Now gas odor??? cmedeiros17 YJ Wrangler Technical Forum 6 10-14-2009 12:08 PM
Replaced fuel pump assembly... Jim Shanks TJ Wrangler Technical Forum 1 11-09-2004 11:04 AM
Replaced fuel pump & no gas to fuel rail Part 2 BrianBC YJ Wrangler Technical Forum 0 08-24-2004 07:20 AM
Replaced fuel pump & no gas to fuel rail BrianBC YJ Wrangler Technical Forum 11 08-22-2004 10:41 PM
