To anyone who has replaced a fuel pump. - JeepForum.com
post #1 of 32 Old 02-24-2009, 07:58 AM Thread Starter
Levinz11
So I checked the realy and fuses. Checked all connections that are possible to get to with out dropping the tank. And have come to the conclusion that my fuel pump has **** the bed. No warning at all. The heep drove fine to work, then when I was going to lunch it started but quickly started to gurgle and proceeded to die. I tried a few more times but gurgle, gurgle, gurgle...die. I replaced the fuel filter in the parking lot and no go.
My question for you guys is this. Since there are quite a few brands to choose from, which is the best and most complete brand of fuel pump. By complete I mean hoses, gaskets, screens everything I need to get the job done and not have to run to the parts store 3 times. Or if anyone has a list of required parts for the install that would be great.
Thanks
PLEASE DEPOSIT $.75
Levinz11 is offline
post #2 of 32 Old 02-24-2009, 08:27 AM
dgasw
1987 YJ Wrangler
fuel pump
I replaced mine about a year ago. I just went to NAPA and got the Bosch fuel pump kit (NAPA P/N "BSH
N69302 " Bosch fuel pump kit, it comes with the inlet screen, the pump, the rubber hose that connects the pump to the metal line,two clamps, new wires and some orings. Get a new rubber gasket for the top mounting area(I don't have the part number for the gasket.) I do remember that I had to reorder the gasket because the wrong one came in. Mine is from a 93' 4.0l and it is rectangular but the one that came in the first time was round. Not sure if it was my fault or NAPA's.
dgasw is offline
post #3 of 32 Old 02-24-2009, 08:30 AM Thread Starter
Levinz11
Thanks for the info man. I was looking online and some kits come "complete" and some just come with the pump.
So the gasket is square shaped on a 91 not round right?
PLEASE DEPOSIT $.75
Levinz11 is offline
post #4 of 32 Old 02-24-2009, 08:36 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Have you gone thru the full trouble shooting of this???
I hesitate to fire right at changing the fuel pump. Do you hear it prime when you turn the key to on(not starting it)?????
Did you check the shrader valve on the fuel rail to see if you are getting fuel????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 32 Old 02-24-2009, 08:41 AM
jeepster93
jeepster93's Avatar
Just replaced my fuel pump on my '93 4.0. Died the same way yours did...one minute it was fine, then it would not restart.
There are 2 fuel pumps listed in the parts books for this engine. I needed to take the broken pump to my local NAPA to match it. it turned out to be the NAPA brand pump not the bosch one, which was too physically small. It comes with all the stuff needed to install it(new nuts/bolts, hoses, hose clamps, filter etc) in the box with the filter.
Cost was about $125.
Took a few hours, mostly dropping and reinstalling the tank, it is in there fairly tight.
jeepster93 is offline
post #6 of 32 Old 02-24-2009, 10:10 AM Thread Starter
Levinz11
Before I went to swap the filter I released the pressure at the rail and it wasnt much at all. Pump does not prime with key turned. I even left the filter off and turned engine over and nothing, not even a drop came out the hose going back to the tank.
I haven't gone through the complete troubleshooting I guess. Am I missing something?
PLEASE DEPOSIT $.75
Levinz11 is offline
post #7 of 32 Old 02-24-2009, 10:11 AM Thread Starter
Levinz11
So did you get the Bosch or NAPA one Jeepster?
PLEASE DEPOSIT $.75
Levinz11 is offline
post #8 of 32 Old 02-24-2009, 10:13 AM
Yury
not to bust chops and it might be astupid question but do you have gas in the tank. my yj fuel gauge was shot and i ran out of gas ones untill i learned how to eyeball it
Yury is offline
post #9 of 32 Old 02-24-2009, 10:13 AM Thread Starter
Levinz11
I clamped the hose going into the filter before removing. To test the pump after filter removal I released the clamp and turned engine over. Nothing came out. I put in three gallons just to be sure I didn't run it dry.
Is this normal????
PLEASE DEPOSIT $.75
Levinz11 is offline
post #10 of 32 Old 02-24-2009, 10:14 AM
rustywrangler
Do you have power close to the tank??? when you said checked the relay, do you mean hear it click when someone turns the key???
You can swap the relays around to see test as well.
post #11 of 32 Old 02-24-2009, 10:15 AM Thread Starter
Levinz11
My gauge doesnt work either. I thought I had run it dry, so I added three gallons just to be sure.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #12 of 32 Old 02-24-2009, 10:15 AM
rustywrangler
Is this normal????
If the pump is not priming or does not have power to it, you will not have fuel come out.
post #13 of 32 Old 02-24-2009, 10:16 AM Thread Starter
Levinz11
Yes, power seems to be flowing fine throughout. I swapped A/C and horn relays, nada.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #14 of 32 Old 02-24-2009, 10:17 AM Thread Starter
Levinz11
That was one thing I wasn't sure of. Thanks.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #15 of 32 Old 02-24-2009, 10:17 AM
rustywrangler
Well then I guess the pump or connections at the pump are the next step. Sorry, was just trying to troubleshoot abit for ya.
replaced relays but Fuel Pump still doesn't prime lexinator02 YJ Wrangler Technical Forum 10 12-28-2009 10:29 AM
Fuel Pump Replaced- Now gas odor??? cmedeiros17 YJ Wrangler Technical Forum 6 10-14-2009 12:08 PM
Replaced fuel pump assembly... Jim Shanks TJ Wrangler Technical Forum 1 11-09-2004 11:04 AM
Replaced fuel pump & no gas to fuel rail Part 2 BrianBC YJ Wrangler Technical Forum 0 08-24-2004 07:20 AM
Replaced fuel pump & no gas to fuel rail BrianBC YJ Wrangler Technical Forum 11 08-22-2004 10:41 PM
