Anyone using Seals-It axle seals? - JeepForum.com
post #1 of 17 Old 08-28-2014, 01:19 PM Thread Starter
ghetdjc320
Saw these online and they look pretty sweet but I'm not sure if anyone has ever used them.
http://sealsit.com/lowcostaxleseal.asp
I'm wondering if they will fit the passenger side with the CAD side? I am going to keep my CAD for now. I installed a Cable lock system along with an aussie locker and love the setup. I have to replace my drivers side axle seal though and wanted to use something stouter than the flimsy stock seals. Also has anyone had any luck using tube seals on their disconnect axles? I know the ones from Alloy USA are very specific in size but I've seen some from OX that seems to be more universal. I assume the problem is fitting the large splines of the disconnect axle through the tube seals?
thanks
-DJC
ghetdjc320 is offline
post #2 of 17 Old 08-28-2014, 01:34 PM
TSEJEEPERS
Not sure about those but the ones made by Ten factory will not work with the disconnect.
They will work if you go to one peice shafts though.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 17 Old 08-28-2014, 01:41 PM Thread Starter
ghetdjc320
Just got off the phone with the tech support guys at seals-it and they say they will fit. They also sell tube seals they say will fit the disconnect axle. I'll order some and post back with the results. It would be nice to have a tube seal that fits the disco axles.
-DJC
post #4 of 17 Old 08-28-2014, 06:46 PM
medic-11
Funny you should post this. I am re-gearing my Dana 30 right now, and contemplating what I am going to do for seals.
You are correct, that most aftermarket seals will not fit over the disconnect shaft as it is larger. I don't remember the actual size- but its about a 1/4 larger diameter than the drivers side shaft. The disconnect splines are the largest part, and may prove difficult to get a seal over it, yet still seal to the shaft at the outboard end.
I have nearly come to the conclusion that I will build my own seals. You can search for a seal with adequate specs pretty easy on the internet. Ive found a few for ~$6, available at Autozone locally. What I was thinking, is casting a whole assembly, seal "housing" and seal in one piece of polyurethane, or as a plan "B", casting a seal holder from polyurethane and buying a replaceable seal to insert into it. I think if I chose the right hardness polyurethane for a one piece seal/holder, it would seal nice enough to the inside diameter of the housing, and provide a lip seal durable and pliable enough to ride the axle shaft. My friend does composites and mold making for Disney. I plan to get his opinions very soon, so I can decide if I want to try this or not.
medic-11 is offline
post #5 of 17 Old 08-28-2014, 09:59 PM
gtg413i
2003 WJ
Yes. I tried the outer seals with no success. Put the seals- it in, then the stock seal. Well worth the piece of mind not having to do it twice. I have tj dana 30 axles though.
Brian's Black Betty Build:
gtg413i is online now
post #6 of 17 Old 08-30-2014, 09:41 AM Thread Starter
ghetdjc320
I figured the seals-it will fit the drivers side but what about it fitting the passenger side? Did you use both seals. Why didn't the outer tube seals work?
-DJC
post #7 of 17 Old 08-31-2014, 06:21 AM
Jeepsr4me
There is no way it will work on the stock shaft passenger side. If you ever pulled the shaft out you will see that the end splines are about twice the size of the shaft. So not sure how a collar would get over that AND be able to seal..
Jeepsr4me is online now
post #8 of 17 Old 08-31-2014, 09:06 AM Thread Starter
ghetdjc320
At the splines and seal the axles about 1.4" in diameter. Does it neck down all the way to 1.069" like the drivers side?
-DJC
post #9 of 17 Old 08-31-2014, 11:00 AM
Jeepsr4me
I have a spare shaft I measured
post #10 of 17 Old 08-31-2014, 11:22 AM
sardog211
I got 99 cherokee shafts, I used this seals it, and pull ddd the carrier and installed it, I also used the axle seals made by ten. I have had no leaks and zero issues with this seal, for me it worked great, take this as my 2 cents but it worked for me.
sardog211 is offline
post #11 of 17 Old 08-31-2014, 11:29 AM
Jeepsr4me
Thats because the cherokee shafts are like the TJ shafts, mostly all one size from spline to end. the YJ as I posted above varies enough to tear the seal as it was slide on..
post #12 of 17 Old 08-31-2014, 11:42 AM Thread Starter
ghetdjc320
So iirc the stock shaft is just 1.069 that would make the passenger side equivalent to a 31ish spline?
-DJC
post #13 of 17 Old 08-31-2014, 11:43 AM Thread Starter
ghetdjc320
I am planning to try to fit the 30 spline tube seals from alloy on the passenger side and a regular one on the drivers side. I'll post back if this works
-DJC
post #14 of 17 Old 08-31-2014, 12:21 PM
timatoe
timatoe's Avatar
The only reason the seals don't fit the disco is because of the larger end at the CAD, not the actual shaft portion. There was a write up on here where someone pulled an Alloy USA (or similar) apart to get it over then put it back together. If you get one for a larger diameter shaft, it's not going to seal at the end of the tube/shaft.
timatoe is offline
post #15 of 17 Old 08-31-2014, 01:24 PM Thread Starter
ghetdjc320
According to the axle diameter of the disco axle where it comes out of the tube the diameter is 1.348" vs 1.31" on a 30 spline shaft. So in theory if I can get it over the splines which are 1.6" it should seal perfectly. Rite?
-DJC
