Anyone use the Exploder rear drive shaft? - JeepForum.com
post #1 of 5 Old 03-30-2010, 04:13 PM Thread Starter
timatoe
timatoe's Avatar
Just what the title says. I pulled another 8.8 yesterday and can get the rear shaft for nothing. Has anyone had the Exploder axle cut down, I've also got a XJ shaft but the Ford one looks WAY beefier. I understand the u-joints are a different size, but if I use a 1330 - 1310 at the top and the stock flange at the axle would it work?
The only thing I noticed is the slip joint in the stock shaft looks kinda short. Oh, and yes the top end of the Exploder shaft is a double cardan.
I figure if this will work I'll keep the XJ shaft and the 1310 flange I've got for that as a spare set up.
Thoughts?
timatoe is offline
post #2 of 5 Old 03-30-2010, 10:31 PM Thread Starter
timatoe
timatoe's Avatar
Thousand of guys out there running a 8.8, surely I'm not the only knucklehead to think of this.
timatoe is offline
post #3 of 5 Old 03-30-2010, 10:39 PM
jbolty
jbolty's Avatar
I grabbed one when I was planning mine but never used it because I got a good deal on a TW. But, at the time I was thinking the slide was pretty short and did not have a grease fitting. No reason it won't work though.
jbolty is offline
post #4 of 5 Old 04-01-2010, 08:49 AM
bpr
I grabbed one with my 8.8 also but haven't used it. It is a single cardan DS though. I would have to have a 1310 CV put in when I had it shortened so I just used an XJ instead.
bpr is offline
post #5 of 5 Old 04-01-2010, 09:58 AM Thread Starter
timatoe
timatoe's Avatar
They may have used different ones for different years, IDK. But this one is definitely a double cardan and has a flange mount at both ends, I've got the back half in the garage, I left the CV/Double Cardan end on the truck (it's at my buddy's body shop).
timatoe is offline
Question on Ford Exploder CV drive shaft bloopy901 YJ Wrangler Technical Forum 5 07-21-2009 07:56 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 04:33 PM
CV rear drive shaft? Goobersbro YJ Wrangler Technical Forum 6 10-28-2008 12:22 PM
POLL: Ok to Drive w/ rear drive shaft? Libtekguy TJ Wrangler Technical Forum 14 07-02-2008 12:25 PM
Can I drive without my rear shaft? TomC TJ Wrangler Technical Forum 12 09-13-2004 09:31 AM
