Anyone running Revolvers on the front? - JeepForum.com
post #1 of 3 Old 08-14-2011, 02:05 PM Thread Starter
chris_ce
I bought a 94 a while back and it has Revolvers on the front. They are installed upside down. Does anyone know a reason why someone would do this. Looks like the drivers side might hit the steering box bolt if I flip them over.
Reason I ask id that my springs look twisted in the front. I re torqued everything but still look twisted. Jeep drives great on the road so I don't know if it's something to worry about or not.
chris_ce is offline
post #2 of 3 Old 08-14-2011, 04:05 PM
JamesHasler
I think revolvers work great....if you have open diffs. With lockers, you can get some mean axle wrap.
I had them front and rear with open diffs and they worked great. Lots of flex (if you match them to longer shocks, etc.) But once I got a rear locker, the rear revolvers gave me all sorts of headaches as the rear end would hop and traction would suck.
Now, I still have revolvers up front (open) and they still work great as I have modified shock towers and longer brake lines...
In terms of why they are upside down, I'm not sure. The front and rear revolvers are different. The fronts have a different geometry to clear the power steering unit. The two halves are asymmetric, whereas the rears look more symmetric.
Hope that helps!
James
JamesHasler is offline
post #3 of 3 Old 08-14-2011, 04:19 PM
levergun
1979 CJ5
I don't see any reason for that. I have them on the front of my cj and I hate them. They do all kinds off wierd things. Especially if you hit some big bumps or ridges at higher speeds. They do help flex off road but I don't think it's worth it. I'm about to go to boomerangs on mine. They work way better IMO.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
revolvers 88blkyj YJ Wrangler Technical Forum 6 04-14-2011 07:53 AM
Revolvers? TJ TRunner YJ Wrangler Technical Forum 5 01-28-2007 04:52 PM
Anyone Running Revolvers?? mrobertson YJ Wrangler Technical Forum 1 08-08-2006 02:37 PM
Revolvers in the rear...?? in the front. bigsteve3184 YJ Wrangler Technical Forum 5 02-22-2002 10:19 PM
Revolvers rayray YJ Wrangler Technical Forum 19 03-06-2001 01:32 PM
