Anyone Running A Electric fan? - JeepForum.com
post #1 of 31 Old 03-19-2007, 04:36 PM Thread Starter
wrecks30
I was just interested in going to an electric. and maybe get a couple more horses from my 2.5, cause I need all I can get, If anyone has done this, How do you like it? was hard to install? do you get any more power?
Thanks
wrecks30 is offline
post #2 of 31 Old 03-19-2007, 04:51 PM
ckiel24
To be honest, I dont think you will be able to tell much of a difference power wise just by switching to an eletric fan. For a little bit more you could just swap in a 4.0, assuming you can do the work your self
ckiel24 is offline
post #3 of 31 Old 03-19-2007, 06:38 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Thanks
I put a Mark VII fan on my 2.5. Although I haven't been on the freeway yet, I can sure feel the difference around town. I got it off a '96 Mercury Cougar with a 4.6L V8. It has 2 speeds, but I haven't needed the high speed yet. I also set it up so I can turn it off in deep water. With a cheap $17 thermostat and some 50 amp relays, I'm good to go.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #4 of 31 Old 03-19-2007, 07:49 PM
Swampwalker3
1987 YJ Wrangler
You have some hellacious space under your hood, Mr. B.
Zane Neher
88 YJ. H.O. 4.0L/AW4/twin sticked d300/1 tons/38.5s.
Swampwalker3 is offline
post #5 of 31 Old 03-19-2007, 10:10 PM
1 ton yj
1 ton yj's Avatar
I have a Taurus 3.8 fan (I think it's the same as the Mark VIII) wired on high. Keeps my 350 cool all summer long.
1 ton yj is offline
post #6 of 31 Old 03-20-2007, 05:47 AM
vadslram
I switched over to an electric about 3 weeks ago. It's been cool here so I've only had the fan come on a couple of times.
But I did notice a marked increase in power. I've only run two tanks through so far but it seems like I'm getting better milage, tough to tell since I'm having too much fun with the extra horsies.
vadslram is online now
post #7 of 31 Old 03-20-2007, 07:08 AM
Jeepfreak81
Jeepfreak81's Avatar
Electric fan... couple hundred bux TOPS... 4.0 swap... a thousand at LEAST Not to mention the downtime of the rig and labor....
I run the Taurus fan too with my V8... $45 for the fan, and I had $70 more into it for the fan t-stat and Bosch relay. -- ignore that one through the rad mount, I needed to make one more bracket.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #8 of 31 Old 03-20-2007, 07:16 PM
Mr.B
Mr.B's Avatar
I'm thinking of putting a compressor tank in there. And maybe a popcorn maker.
I think the motor is the same 2 speed. The blades and the cowling are slightly different though. The nice thing about the Mark VII is that it was an almost perfect fit.
Do your Taurus blades look like this?
Ham license:
Everyone is Welcome
Mr.B is offline
post #9 of 31 Old 03-20-2007, 07:26 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i ran an electric fan on the 2.5, never could tell the difference myself, in that or the 4.0 t/b etc etc.
i just got the kit for a v6 from my local parts place, never had any issues with it.
think the relay/thermostat deal was all bosch.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #10 of 31 Old 03-20-2007, 10:35 PM
1 ton yj
1 ton yj's Avatar
No they are straighter. Does your's make a ton of noise like mine does?
1 ton yj is offline
post #11 of 31 Old 03-21-2007, 02:30 AM
yjing
Im looking to do this for the spring/summer. Does anyone have or know of a write up on EVERYTHING needed to swap in an electric fan? I have an electric fan, thats it. What else is needed? Easy to do? Cost of accessories? Thanks a lot!!!
89er 4banger
Red Jeep Club Member #360
yjing is offline
post #12 of 31 Old 03-21-2007, 08:14 AM
Mr.B
Mr.B's Avatar
Only when it's running.
I actually have an LED in the cab that goes out when the fan is running, because when I'm driving down the road I can't hear it.
Ham license:
Everyone is Welcome
Mr.B is offline
post #13 of 31 Old 03-21-2007, 08:21 AM
BigMikey
I have an electric fan i bought off quadratec a while back. I as well did not notice any power gains. I def. like an adjustable fan because when your in the trail moving at slow speed high RPMs i can set the fan to come on at any time and it keeps my engine at the temp i set it at. Its great.
BigMikey is offline
post #14 of 31 Old 03-21-2007, 08:37 AM
Tulsachokehold
I have a Grand Cherokee fan waiting to go into my Yj. I am not totaly sure if it is a multi speed fan, but I will be wiring it in so I can tuyrn it on and off at will. this allong with a trany cooler should make things a bit cooler under my rig.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline
post #15 of 31 Old 03-21-2007, 09:12 AM
Jeepfreak81
You don't have a wiring diagram on how to do this do you?? I have overheated twice because I bumped/.turned off the switch and didn't double check it.
Anyone running an electric fan? skouklis TJ Wrangler Technical Forum 5 02-13-2010 08:49 AM
What size electric fan are you guys running on 4.0L jonlb YJ Wrangler Technical Forum 5 04-12-2009 02:51 PM
Anyone running an electric fan kevin_tall_jeep YJ Wrangler Technical Forum 25 02-20-2009 07:24 AM
For those running aftermarket electric fuel pumps with the factory tank Jeepfreak81 YJ Wrangler Technical Forum 4 02-10-2008 09:23 PM
anybody running electric fan in 4.0 GiVeN-R TJ Wrangler Technical Forum 15 02-09-2005 10:22 PM
