Anyone run a RC lift with 1/2" lift boomerang shackles and only TC drop? - JeepForum.com
post #1 of 12 Old 04-09-2010, 11:42 AM Thread Starter
MA88XJDude
I just finished installing my Rough Country 4" lift kit on my 88 YJ last night.
However, the rear shackle angle is really bad (almost in line with the spring) and the front is a little over 90 degrees. So first off, I know that the springs are brand new and need to settle a little but it seem's like the stock length shackles are too short for the springs or vice versa.
I was going to contact RC and see if maybe they are deffective springs as I have heard of this before.
SO the question is:
Could I run a 5" eye to eye boomerang shackle (1/2" of lift) to help with the angle? I cant really afford a SYE right now, so I have to stick with the T case drop kit for now. Has anyone done this?
Sorry for no pics, Im in school right now but I'll snap some when I get home.
88' YJ/CJ Turbo Diesel
MA88XJDude is offline
post #2 of 12 Old 04-09-2010, 11:52 AM
MLJeeper
MLJeeper's Avatar
What degree shims are you using? Higher angle shims combined with a MML or something like that should get you where you need to be. Taller shackles will turn the angle up some to.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 12 Old 04-09-2010, 01:42 PM Thread Starter
MA88XJDude
Eh...I dont know, if I was going to go through the trouble of doing a MML I think that I would just save my money and buy a SYE and get a front cherokee shaft shortened....
Also Im not sure what degree shims I have, they are the ones that come on the RC springs.
So I called RC and the tech said that it would be ok and that I just need to drive my YJ around and get the springs to sag.....but Im not happy with that answer.
So Im still looking to know if anyone runs a 4" RC kit with a 1/2" boom shackle lift and only the TC drop.......
post #4 of 12 Old 04-10-2010, 06:49 AM Thread Starter
MA88XJDude
bump, nobody run's a RC w/ 1/2" shackles? if not then what do you guys reccomend I do? nothing? SYE is a must down the road (I want to anyways)?.....
post #5 of 12 Old 04-10-2010, 06:39 PM
2uraven
I have the boomerang shackles and it added closer to an inch. i got an RE 2.5 lift and it turned out to be 4" over all. you probably have 2* shims and could try 4* or maybe six and get rid of the tc drop.
2uraven is offline
post #6 of 12 Old 04-10-2010, 07:19 PM
berretaman
I have recently put a RC 4" lift and 5/8 boomerang shackles which is close to 1/2" and have no vibes at all, but every jeep is different so take that into consideration. I also plan on putting a sye but just not at the moment.
berretaman is offline
post #7 of 12 Old 04-10-2010, 10:17 PM
alifted4x4
2009 JK Wrangler
I have a RC 4" on my 1990 YJ with a Reverse Shackle in the front and 1"5/8 Boom Shackles in the rear.. I have a little videration at high speeds but not too bad. I have the TC drop but no SYE yet.
alifted4x4 is offline
post #8 of 12 Old 04-10-2010, 10:28 PM
wv2jeep
I have a4in rc lift with 1 inch longer boomarang shackles,so half inch more lift.I used the transfer cace drop with the kit.Afrer everything set in I had to shim the pinion angle down to clear up a slight vib.Friend has exact same setup with no vibes.Iguess everyones is a little diffrent.
wv2jeep is offline
post #9 of 12 Old 04-11-2010, 12:23 PM
harrist
I installed my RC 4" last month, along with 1.25" boom shackles and with a tcase drop, and only have slight vibes around 30-35 mph, but there not too bad... but then again I'm also running a longer shackle...
harrist is offline
post #10 of 12 Old 04-11-2010, 03:21 PM Thread Starter
MA88XJDude
Hmmm.....looks like I'll have to order some 1/2" lift boomerangs and try them out.
Also the angles on my shackles are much better now that I have moved the jeep around.
thanks guys, much apreiciated.
post #11 of 12 Old 04-11-2010, 05:08 PM
lil_joe
I have a 92 YJ 4 inch RC lift, 5/8 boom shackles, 1 1/2" front wheel spacers, and 1" BL, ...........ZERO issues ........been running this set up since 05/09
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #12 of 12 Old 04-11-2010, 08:43 PM
iowajeepers
Ran a 4" RC lift with 3/4" booms with no issues. I am now running a SYE since upgrading to an 8.8.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
1.25 Lift w/ Boomerang Shackles JeepingOnPINS YJ Wrangler Technical Forum 11 08-25-2009 07:07 PM
4" lift + Boomerang shackles fit 35s??? Nate M YJ Wrangler Technical Forum 30 02-28-2009 05:31 PM
should i drop the transfer case with a 2.5" lift and 1" boomerang shackles?? eric0024 YJ Wrangler Technical Forum 5 09-28-2008 11:23 AM
What shocks should I run? 4" springs, 1" boomerang shackles, 1" body lift Dwayne93YJ YJ Wrangler Technical Forum 3 06-03-2008 12:15 AM
Boomerang Lift Shackles JodyYJ YJ Wrangler Technical Forum 6 04-22-2003 09:56 AM
