anyone replace BA10 with a AX15 ? - JeepForum.com
post #1 of 4 Old 09-22-2013, 04:46 PM Thread Starter
krazybob
I have the Peugeot BA10/5 tranny, and I'm considering replacing it with a AX15. I'm wondering if they would be a straight switch without mods ? I'm thinking I'd also have to change the bell housing, since the trannys are shaped different. I have the internal slave cyl and would also like to install the exterior one while I'm at it. I'd also use the transfer case for the AX15 too. Input ?
Krazybob,, Mtn. Home, Idaho
My goal, is to die young,,
at a very old age
1988 YJ 4.2 5sp
krazybob is offline
post #2 of 4 Old 09-22-2013, 05:02 PM
crackedcornish
you should check out the FAQ's newb
here's a link....
http://www.jeepforum.com/forum/f19/y...ite-up-312203/
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 4 Old 09-22-2013, 05:31 PM
rambo3489
It will be direct.. For the most part. You have to ensure you have the .590" pilot tip not the .75. Otherwise you should be mostly good to go. You may run into some problems with the shifter location/linkages. But those are minor.
Check the FAQ linked above that will lay it out much better for you.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #4 of 4 Old 09-22-2013, 05:41 PM
5-90
5-90's Avatar
1988 XJ Cherokee
- Go to www.naxja.org
- Search for "Let this be THE Peugeot to AX-15 Swap Thread."
- Read it through.
- Get a notebook and pen, and read it through again - this time, taking notes.
- You may now consider yourself edified.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
