Anyone put an amp in their glove box? - Page 2 - JeepForum.com
post #16 of 22 Old 07-12-2010, 12:02 AM Thread Starter
Rideout
Update
I was poking around in the hole that is now my glove box, and I think that there is a fresh air vent that passes through where I want to put the amp. My question to you (anyone) is: "can I remove this?" Is it just an empty pipe that carries the fresh air, or is there something else in there?
I am going to try to post some pics. I have the pipe circled, as well as the vent that comes out near the driver side floor.
I probably don't need a fresh air vent since the top is usually down, and if not (i.e. in the winter) I just unzip the window.
Rideout is offline
post #17 of 22 Old 07-12-2010, 04:43 AM
MacGyver1138
They make small 2 or 4 channel amps, why not get one that will fit where your radio would be, and put a metal plate over the opening.
Something like this, 2-Channel 240-Watt Waterproof Marine Amplifier
MacGyver1138 is offline
post #18 of 22 Old 07-12-2010, 06:44 AM
MoparFreak69
You could take the fresh air box out but you are going to have to fill some holes and find a way to seal the entrance which is the vent hole between the hood and windshield there in the center. I disabled my vent cable, and usually dont like to use a vent anyway so I may be thinking the same thing about mine. Let us know how it works out if you decide to go that route.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #19 of 22 Old 07-12-2010, 08:56 AM
Dwayne93YJ
Dwayne93YJ's Avatar
Make sure that your cowl/windshield seal works well, hate for water to get into that area and damage your amp. Common area for a water leak in YJs.
Dwayne93YJ is offline
post #20 of 22 Old 07-12-2010, 04:06 PM Thread Starter
Rideout
Thought about that too. Looks like a decent amp, and the price is right on amazon, so if it sucks I won't loose out on much more than time.
I still think I am going to take out the vent and fab something for that area. It seems ridiculous to have a fresh air vent in an open top jeep...and I could totally use that space.
Going to make sure it is well sealed though, like Dwayne said.
Will keep you posted
Rideout is offline
post #21 of 22 Old 07-14-2010, 06:47 PM
rixxs00
I mounted my amp above my fender well in the back and made this cover for it.
rixxs00 is offline
post #22 of 22 Old 07-14-2010, 11:40 PM Thread Starter
Rideout
That is pretty nice.
I like the idea b/c it is up high enough that I won't worry about going through streams, and with that lid, I could still stack gear on top.
Can you provide some specifics. What's it made of, is it removable, and does it get hot?
Thanks for the post
Rideout is offline
amp , dash , jeep yj , sahara
What is this behind my glove box? BigOrange90YJ YJ Wrangler Technical Forum 5 09-14-2009 09:09 PM
Looking for OEM Glove box for 99 TJ Bill M. TJ Wrangler Technical Forum 0 04-25-2009 12:54 PM
Tuffy glove box Jeepdrivinmid TJ Wrangler Technical Forum 8 01-01-2007 06:50 PM
Tuffy glove box Jeepdrivinmid TJ Wrangler Technical Forum 12 12-06-2006 11:31 AM
takin out the glove box UCF YJ'r YJ Wrangler Technical Forum 7 11-05-2006 01:26 PM
