anyone pull the carpet and use bedliner ? - JeepForum.com
post #1 of 25 Old 09-01-2014, 11:54 AM Thread Starter
krazybob
I'm thinking of pulling my floor carpet, and using bedliner paint on the floor. Lots easier to clean after a day having fun Any thoughts about roll on, brush on, spray on ? Also a possible brand that may work best ? Running just a bikini top, no hardtop, or with the wife's allergies, I doubt I could use it because of possible smell. Or,, maybe that isn't an issue with bedliner paint ?
Krazybob,, Mtn. Home, Idaho
My goal, is to die young,,
at a very old age
1988 YJ 4.2 5sp
krazybob is offline
post #2 of 25 Old 09-01-2014, 12:07 PM
mrmud4x4
I've got no carpet....just stock paint...easy to clean out.
just google DIY bed liner....lots of choices...
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #3 of 25 Old 09-01-2014, 12:20 PM
Jeepsr4me
One TIP.... get the liner that is smooth as possible IF MUD is in your diet... Getting mud stains out of rough bed liner is a ppain.
Jeepsr4me is offline
post #4 of 25 Old 09-01-2014, 12:23 PM
Reno72
I did roll on bed liner and it worked great, no smell after drying. That said, I reinstalled my carpet for three reasons. 1. It stays cooler in the summer, it surprising how much of the heat from the cat and motor is blocked by the carpet and heavy felt backing. 2. It's seems warmer in the winter, metal transfer the cold way to well. 3. And this is minor, but the jeep is quieter inside especially with the top on.
Reno72 is offline
post #5 of 25 Old 09-01-2014, 12:44 PM
mrmud4x4
here's what I did to the exterior....fix'n to do a durabak 18UV smooth coat over it....tough stuff!
http://www.jeepforum.com/forum/f12/s...-rough-914927/
clean it with 409 and a scrub brush....tree branches come off on my paint...
mrmud4x4 is offline
post #6 of 25 Old 09-01-2014, 12:57 PM
Wazzier
Have to recommend a 1gal Monstaliner kit man. Have my whole tub done in the stuff for the past year and not a scratch. Not even fading at all. Smooth and easy to clean when done to!
Wazzier is offline
post #7 of 25 Old 09-01-2014, 01:00 PM
mrmud4x4
I was thinking about monstaliner for the interior....
What color...black?
mrmud4x4 is offline
post #8 of 25 Old 09-01-2014, 01:21 PM
Wazzier
Mines black.. Whatever you like really. Could paint it your body color so it looks more stock\clean!
Wazzier is offline
post #9 of 25 Old 09-01-2014, 05:10 PM
IA93Javert
You can tint the monstaliner to about any color you want. I am looking to do the same.
IA93Javert is offline
post #10 of 25 Old 09-01-2014, 05:22 PM
Wazzier
They sell the tint as well.. You can order a test chip bag with all the colors off their site under $10.
Wazzier is offline
post #11 of 25 Old 09-01-2014, 06:32 PM
snowplowdog
The PO of my Jeep did the bedliner, unfortunately he didn't prep the inside of the tub first so it's peeling off in sheets. I did the same thing Reno did, carpet, since it's also my daily driver, and it does make a difference as far as heat/cold and noise.
Never attempt anything you don't want to have to explain to the EMT
snowplowdog is offline
post #12 of 25 Old 09-01-2014, 07:58 PM
95YJLS
A coworker had his YJ tub Rhinolined professionally. He loves it, but after a few years with the top off the black is fading a little.
I can't speak from experience, as mine is still sitting in cans, but I chose Monstaliner after doing the research. Also, Jeepforum members get some bonuses with Monstaliner.
95YJLS is offline
post #13 of 25 Old 09-01-2014, 10:51 PM
timatoe
timatoe's Avatar
I did this a long time ago and used the Herculiner roll on kit. It's held up ok everywhere but under my right heel. I later sprayed the entire exterior in Monsta Liner. If I were to do the inside again I'd go with the Monsta there too.
timatoe is offline
post #14 of 25 Old 09-02-2014, 12:16 AM
Drednot
Pulled carpet. Stock paint underneath is easiest to clean mud and dust. No bucks, no prep, no work.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #15 of 25 Old 09-02-2014, 05:00 AM
jeep63
jeep63's Avatar
I have done Monstaliner on two jeeps and have rhino on my 89.
Rhino is 10 years old and going strong. The 2 Monstaliner jeeps are only 1 year into use. I did it to match each jeep. One red and one white. I like the "stockish" look. I did put carpet back in the 91 to keep noise and heat/cold transfer down. That jeep is all street and driven by my wife some.
The white one sees a lot of sand so I am not sure about the longevity since it basically has sand paper on the floor a lot. Time will tell.
jeep63 is offline
