Originally Posted by 1obie1
My daughters 94 jeep larado is having brake light problems,when you press the brake pedal down the hazards come on and only with the key on.nothing with the key off.If you turn the hazards on the brake lights go solid.Anyone have any thoughts? thanks
What about the turn signals? are there problems with them also? I would check for:
Bad bulbs or
wrong bulbs.
Then I would check the ground that is right on the right front (passengers side) radiator support. The rear lights are case grounded.
There are two flashers in the fuze panel under the dash one is for the turn signals and the other is for the hazard flashers. They can get 'stuck' also. I have pulled mine out removed the cover and 'adjusted' the contacts to make them work but replacing them is easy also.
