Anyone have a pic of the fuel lines,etc on top of gas tank? - JeepForum.com
post #1 of 12 Old 09-21-2006, 03:46 PM Thread Starter
wwiihistory
wwiihistory's Avatar
Just wondering....maybe one of you guys took some pics during a restoration or something...
Happiness is a belt-fed weapon
95 Sahara, 4.0L, 5 spd, Olive/Tan, HT,HD's, 31's,3.07s
Military Jeep club member 1941,1942,1943,1944, and 1945
wwiihistory is offline
post #2 of 12 Old 09-21-2006, 03:52 PM
E_ROCK
I might have one when I pulled the gas tank. The only problem is it is on my home computer and my house is being carpeted. So, it will be a couple of days before I get a chance to set-up my computer. If no one has responded by saturday and you still need the picture, let me know.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #3 of 12 Old 09-21-2006, 04:05 PM
crosschecker
1995 XJ Cherokee
What is it you're trying to figure out? There are two lines for fuel and a vent line with two connections to the tank. Not sure if that's any help.
crosschecker is offline
post #4 of 12 Old 09-21-2006, 04:11 PM
E_ROCK
No, there are three, a fuel suppy, fuel return, and a vent. There are also the two filler hoses.
E_ROCK is offline
post #5 of 12 Old 09-21-2006, 05:43 PM
crosschecker
1995 XJ Cherokee
Actually, what I said was correct,
Also, the filler hose and another large vent line. If you're going to try and nitpick, make sure you are correct.
post #6 of 12 Old 09-21-2006, 05:45 PM Thread Starter
wwiihistory
well I can see a rubber hose coming from the top of tank which meets up to a hard line with a hose clamp. It is blowing fuel out when engine running. It appears that there is excess hose where I could cut a few inches off and reconnect for a new fresh connection but I was thinking:
1) just fix the hose and be on my way again (by the way, if tank is not drained will it start siphoning out through pump in tank during repair?)
2)drop the tank....and replace all rubber hoses since I have no idea on the condition or time since new (possibly 11 years old).
this fuel line just blew on the way home the other day and I have been fighting a running rich problem for wuite some time (see other thread). I am wondering..if this happened to be the return-to-tank line and maybe was plugging up not allowing unneeded fuel to return....would this give me a rich condition even if everything was good up front?
post #7 of 12 Old 09-21-2006, 05:51 PM
crosschecker
1995 XJ Cherokee
If you have a fuel injected engine, that's what I have, you can relaese the pressure in the system by taking the cap off the pressure test port on the fuel rail and depress the valve in the test port. That should spray some fuel and release pressure in your system. Then you can go ahead and try and repair the line. There will probably still be fuel in the line but not much. As for the rich condition, you're on your own, can't help with that.
post #8 of 12 Old 09-21-2006, 05:56 PM
jeepster93
jeepster93's Avatar
I do have a couple of pics...but only a link to it as I am still new here.
These are when I installed my Kilby.
By the way... That rubber gasket in the 1st pic is a chrysler recall item for early yj's(it should be thick like mine, not a thin gasket)
jeepster93 is offline
post #9 of 12 Old 09-21-2006, 05:58 PM Thread Starter
wwiihistory
Thanks jeepster!
post #10 of 12 Old 09-22-2006, 11:16 AM
E_ROCK
Actually, what I said was correct, Also, the filler hose and another large vent line. If you're going to try and nitpick, make sure you are correct.
Sorry, this is my bad. I didn't see the plural on the words "fuel lines" the first time I read it. My apology!
E_ROCK is offline
post #11 of 12 Old 09-22-2006, 07:25 PM Thread Starter
wwiihistory
well, I took a better look under it today and I pretty sure where the leak is coming from.
The rubberreturn line that comes from tank between the frame and body (sits in a rubber grommet) was not long enough to reach the stainless fuel line so someone at some point inserted a metal tube along with another short rubber hose and some clamps to reach the hard line. I can see a rusty 1/8" gap between the two and suspect it has a nice hole in it.
The rubber hose that is coming from the top of tank to this connection is pretty soft as well. I plan on dropping tank and replacing both with new and make thm long enough.
Questions is: In the thread on page 1 about replacment filter hose someone mentioned using fuel injection rubber hose instead of regular 5/16". Is this a strongly recommended idea since it will be in a not-so-easy to access area?
thanks
post #12 of 12 Old 09-24-2006, 07:27 AM Thread Starter
wwiihistory
well, I spent yesterday afternoon and into evening dropping gas tank and changing the fuel line from tank. They were the higher pressure lines installed to start with. I just made sure to have extra hose. To eliminate kinks of the hose , I made 1 360 curl to the filter inlet.
The only real pain in the *** was trying to remove the bolts of the exhaust hanger plate on the rear frame rail....
Fuel Tank Vent Lines for a 2.5l JonD YJ Wrangler Technical Forum 2 03-26-2008 02:13 PM
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 04:07 PM
'04 Gas Tank Fuel Lines... thejafe TJ Wrangler Technical Forum 2 04-15-2007 12:35 AM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 09:38 AM
Need fuel lines and tank kg6mti YJ Wrangler Technical Forum 1 11-21-2004 10:08 PM
