Anyone have/had a centerforce clutch? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Anyone have/had a centerforce clutch?
RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive Gar
Unread 10-13-2006, 04:13 PM   #1
merlin7782
Bought one of there dual friction clutches for my 93 wrangler, wondering if it was a good choice.. Waiting for my new transmission to come in to test it out...
merlin7782 is offline   Reply With Quote
Unread 10-13-2006, 04:26 PM   #2
GrayT
Stock clutch works fine for mine and pretty much everyone elses needs. Why did you get such a powerful clutch?
GrayT is offline   Reply With Quote
Unread 10-13-2006, 04:29 PM   #3
merlin7782
more holding power... If I have to change anything, I never go back to stock..
Unread 10-13-2006, 05:00 PM   #4
northjeep
Jeep parking ONLY
northjeep's Avatar
I only have a CF 1 and I think the weights ratle a bit sometimes.
-NorthJeep - >> Just Enough Essential Parts
RED Jeep Club member - YJ Club - 258's Unite
northjeep is offline   Reply With Quote
Unread 10-13-2006, 06:12 PM   #5
Fenix85182
Fenix85182's Avatar
I have heard good things about the Centerforce clutches... pretty much any of them. My plan to drop in a 4.7L stroker with an NV3550 is beginning now, with which I was going to use a CF clutch. Of course, I'm not looking into the clutch or the tranny until I get the stroker built.
Anyway... what transmission are you putting in?
1989 Jeep Wrangler - 4.0 swap, 32" BFG M/Ts, RC lift
1997 Acura 2.2CL
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline   Reply With Quote
Unread 10-13-2006, 08:36 PM   #6
Bob_R
I have the center force II, no complaints at all. Don't think I need anymore than that. I wheel off road a lot.
[B][COLOR="Yellow"]GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL[/COLOR][/B] [COLOR="DarkRed"]TREAD LIGHTLY[/COLOR]
Bob_R is offline   Reply With Quote
Unread 10-13-2006, 08:52 PM   #7
BIGWILL78
I have put the centerforce clutch in almost every manual that I have had, and they have all been great for me! The only stage II that I used was in a pretty extreme rock crawler Jeep, and it NEVER failed on me over many years of abuse, so to answer your question, I would say for sure you made a great choice.
BIGWILL78 is offline   Reply With Quote
Unread 10-14-2006, 12:54 PM   #8
Wrangler95CSA
I had a Centerforce clutch in my rig for a couple of years until I changed out transmissions. Worked great for me while I had it, I beat the living hell out of it on a semi-regular basis. Great holding power, great performance.
1995 Emerald Green Wrangler YJ 2.5L, AX-5, NP231 SYE, 33" x 12.50" X-terrains, 6" ProComp CSC, 4.88's F&R, K&N Intake, Banks Power Exhaust Manifold & Cat Back, MagnaFlow Cat, AirAid Throttle Body Spacer, Rock-It 60MM Throttle Body, Mean Green Alternator, Reverse Glow Halo Gauges, JKS Quick-Disconnects, Energy Suspension Body Mounts, Warn Rock Crawler Bumpers F&R, Warn Spare Tire Carrier, Warn 9.5ti, Brown Dog Motor Mounts, Flow-Kooler Water Pump
My RigRater Score: 501RRv1.0 with a BOA of 21.30
Wrangler95CSA is offline   Reply With Quote
Unread 10-14-2006, 10:09 PM   #9
FLHT_FXRS_YJ
I have a Centerforce between my 4.2 and NV4500. No complaints at all. I really work my YJ, mostly pushing trailers with a front hitch, or pulling them with the rear. When pushing, I'm ususally trying to put the trailer into a tight spot so I'm in 1st gear with a lot of clutch activity. You'd be amazed how much a YJ can pull. Just yesterday, I had to pull a 25 ft, 5600 lb boat on a double axle trailer. It was on the extremely large size, but taking it easy, the Jeep had no problems at all. I guess as far as the Centerforce goes, that is one item I installed that has worked perfectly since day one, with no problems at all.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline   Reply With Quote
