anyone else make this part ????? - JeepForum.com
post #1 of 6 Old 03-11-2010, 11:32 AM Thread Starter
$300xjwith250k
S2572-L, Left 4.0L/4.2L Super Engine Bracket i need one but $150 is a lot for it so
$300xjwith250k is offline
post #2 of 6 Old 03-11-2010, 11:39 AM
jbolty
jbolty's Avatar
junk yard, maybe. But the XJ version is different and good luck finding a YJ scrapped.
If you are tempted to spend the $$, get the whole kit for both sides with the mounts. at least you get a full upgrade.
jbolty is offline
post #3 of 6 Old 03-12-2010, 08:02 AM Thread Starter
$300xjwith250k
bump it ttt
post #4 of 6 Old 03-12-2010, 10:23 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
From my XJ to YJ engine swapping experiences this winter, I know that only one side is different between the two. I believe the driver's side is identical, and the passenger's side is almost the same except the holes for the frame mount is in a different location (might be the other way around). The shape of the bracket is the same, so I can't see why you couldn't drill new holes where the YJ needs them to be. Let me know if you need pics to visualize what I'm talking about. I have a pair of XJ 4.0 engine brackets left over if you want them. PM me if you're interested.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #5 of 6 Old 03-12-2010, 10:30 AM
vector6
if you think it's too much $... why not make your own?
vector6 is offline
post #6 of 6 Old 03-12-2010, 10:47 AM
Boodyrider
Um. Walking home from iles out in the woods sucks when the stock mount bracket breaks, and the new engine block because the mounting bosses on the block broke with the stock bracket is kinda expensive too.
bBrown Dog's stuff is worth every penny... but if you can't swing it, and are willing to live with the limitations of the stock design, get to a junkyard or fab it yourself.
And no, no one else makes the heavy duty block brackets that use all the engine bosses as bolt locations, allowing you to use them even if the stocker broke the bosses on the block as it went.
Brown Dog's warranty is simple: you manage to break it, he gives you another one. He's not too worried... since NO ONE has ever managed to break one.
Can you tell I'm a fan? I have 'em. I love 'em.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
can larger tires make your trans make noises in gear ? rthompson48082 YJ Wrangler Technical Forum 5 09-29-2009 12:35 PM
What's tis part, And does it make noise when starting? mcg311TJ TJ Wrangler Technical Forum 9 09-24-2009 10:04 PM
Mucket Seal part number question (rubber part on door surrounds) commodog TJ Wrangler Technical Forum 6 07-12-2009 07:50 PM
What is this part called and how do i replace it? (engine/air intake part) AlTheKillerr Wrangler General Discussion 3 09-12-2008 08:08 PM
Lets Play..... What part is this part???? NEWtoTHEjeepLIF TJ Wrangler Technical Forum 5 08-31-2005 02:00 AM
