Anyone add a leaf to OME 36R springs - JeepForum.com
post #1 of 2 Old 09-10-2013, 02:20 PM Thread Starter
kgb_m3
I'm running OME 36R on all 4 corners. Jeep sits pretty leveled and has just enough lift to clear my 33s. When I install a hard top, rear end settles down about half inch to 3/4. This has been my concern all along. Soft springs = sag under heavy load.
We're used to loading gear into the Jeep with the hard top on with zero ride height loss. Ride quality of course becomes a trade off. GF and I love OME ride. Having done some research, they do make an add a leaf for 36R springs. Part number D23XL.
Is added leaf worth doing? I would imagine flex taking a hit and maybe the ride comfort. Also since it's a 4.2l, if I was to add a leaf, maybe adding two to the front would benefit further. Opinions?
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #2 of 2 Old 09-10-2013, 02:29 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The 36 R is their heavy spring the spring rate is soft until loaded down then it stiffens up. I wouldn't be concerned by the drop in height my Stock Yj drops 1-1/2" when I put the hardtop and doors on. The aal will make it stiffer. I would go with longer shackles , or Tj flares, or a 1" body before adding an AAL
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
