Anybody put a Toyota 2RZ-FE in? - JeepForum.com
post #1 of 18 Old 08-10-2011, 02:34 PM Thread Starter
Xpress
These little suckers seem to have good power and gas mileage. Moreso than our 2.5L's, so I'm wondering if anybody has ever considered putting one of these in?
Just wondering. Drove my buddies Tacoma Xtra cab the other day and that thing was screaming with me feather footing it like I do my Jeep, and according to manufacturer specs, my Jeep is just a couple hundred pounds heavier...
All about that unibody life.
Xpress is offline
post #2 of 18 Old 08-10-2011, 02:42 PM
oldtime_ironman
I actually wondered about the late-model (last year) chevy 2.9L 4-banger. Something like 189 HP and 28 MPG at least, lots of them in the late Malibu and HHR's.
I *strongly* prefer to keep my Jeep all Jeep tho. I can live with the low power and I love my 4 angry squirrels. Tho I admit the MPFI is prolly the best overall system on them, lots less hassle. Craiglist out my way, I can pick up a complete 2.5 with MPFI and ECU for $150.
Off topic, I was wondering whatever happened with your gas mileage, were the injectors leaking or anything?
oldtime_ironman is offline
post #3 of 18 Old 08-10-2011, 02:43 PM
Andywear
Sounds like a winner!
My trooper with its 4 banger in it had more power than this open top brick I drive now.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #4 of 18 Old 08-10-2011, 02:49 PM Thread Starter
Xpress
Yeah, the gas mileage I've been reading is anywhere from 24 to 30 depending on how hard you run the engine. Even if you could get 22mpg out of it in the Jeep, it'd be worth the swap, as long as you can pick up the engine for cheap (which probably isn't going to be easy).
I'm not entirely sure what it is still. I'm at a stand still with money right now, but a new air filter seemed to help the engines get up and go power, and it seems to do alright on the freeway... Gas mileage went up a bit, but I'm still not at the supposed 17-20mpg I should theoretically be getting with my mens size 4 foot. I'd say I went up from 11 to about 14 with just an air filter.
Xpress is offline
post #5 of 18 Old 08-10-2011, 02:57 PM
oldtime_ironman
Yeah I know how money is - I'm unemployed, which is why I did *everything* to get good MPG's. Next on my list woulda been the O2 sensor and FPR.
By the way, did you know that the Chevy HHR has an SS model with a turbo? And a manual shift? I still wonder about swapping one of those from the local junkyards.
post #6 of 18 Old 08-10-2011, 04:02 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
If i were to swap another 4cyl into a Jeep it would have to be a 4bt diesel , or a Toyota 22RE with come Love from LC engineering
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is online now
post #7 of 18 Old 08-10-2011, 04:32 PM Thread Starter
Xpress
Not sure why you would favor the 22RE over the 2RZ-FE... The 22RE is outdated compared to the 2RZ-FE, which has more power/torque and DOHC. So far they seem to be a very reliable engine for only having been around for less than 20 years...
Xpress is offline
post #8 of 18 Old 08-12-2011, 06:11 AM
Andywear
Bump to remind you of the original plan
Andywear is offline
post #9 of 18 Old 08-12-2011, 09:48 AM
Lemoore-on
I have thought about it as well, the 2RZ-FE exhust dumps out the same side as the 2.5L, I wonder if the tranny & T-case would work too?
Lemoore-on is offline
post #10 of 18 Old 08-12-2011, 09:59 AM
jbolty
jbolty's Avatar
As an aside, the Aisin transmission (AX5 and AX15) is japanese and used in a few toyotas. As I recall the input or output shaft, or maybe both, is different but it's worth doing some research if you're serious.
jbolty is offline
post #11 of 18 Old 08-12-2011, 11:04 AM
Spuznick242
There's only one swap I woudl consider doing and that's the 4BT. Maybe the izuzu version of the 4BT instead of the cummings version but either one is the only way I would go with a swap, if your going to put in that much time, money, and effort, might as well go all the way for the same price....plus it's a little less of a "gray area" as it's been done and documented before.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #12 of 18 Old 08-12-2011, 11:11 AM
92 Green YJ
92 Green YJ's Avatar
just throwing this out there, but i really doubt you would see the exact same mileage in a YJ. first of all the YJ has the aerodynamics of a large brick. so lots of wind resistance the Taco does not have. Also, as you said, the YJ is a bit heavier. Also gear ratios and tire size have a lot to do with it as well. If I'm not mistaken, the Tacos run a pretty deep gear ratio.
And finally, since you live in CA, your gonna have a hell of a time getting the swap approved and smoged. The engine you swap in will have to be the same year or newer than your YJ and ALL smog equipment from the donor engine will have to be re-installed with the new engine. Then you get the joys of dealing with the referee stations and even trying to get in to get it checked over. Unfortunately CA is a real PITA with engine swaps.
Edit: few other potential issues:
Don't think this has been done before as stated above, so you are gonna be on your own as far as motor mounts, trying to find and or make and modify headers to fit, trying to mate up the various systems with the Jeep and gauges and sensors and such.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #13 of 18 Old 08-12-2011, 11:30 AM
Tom95YJ
Tom95YJ's Avatar
I've never really paid any attention to the 2RZ-FE. When it comes to Toyota engines I only have knowledge of the 22RE and the 1JZ-GTE and 2JZ-GTE
Now a 2JZ would be a neat swap in a Jeep
'99 XJ Black Betty
post #14 of 18 Old 08-12-2011, 11:44 AM
Lemoore-on
When I really think about it, if I was to go thru all that trouble why settle for another 4 banger?
I think a 4.0 makes much more sence
post #15 of 18 Old 08-12-2011, 11:46 AM
Tom95YJ
Tom95YJ's Avatar
Maybe he wants to be different
'99 XJ Black Betty
Toyota Axle in a YJ? Chris YJ Wrangler Technical Forum 22 01-22-2009 10:48 AM
8.8 vs toyota axle sitdwnandhngon YJ Wrangler Technical Forum 27 04-30-2008 03:37 PM
toyota axle for a tj? gijoeyb TJ Wrangler Technical Forum 21 03-24-2008 05:27 PM
2007 JK vs Toyota FJ leiopardprey JK Wrangler Technical Forum 39 05-10-2007 11:50 AM
toyota axles bigstinger YJ Wrangler Technical Forum 4 10-27-2006 06:01 PM
