any one swapped a early xj 4.0 into a 2.5 yj - JeepForum.com
post #1 of 3 Old 09-03-2011, 06:10 AM Thread Starter
bft89yj
i picked up an 88 xj for a hundred bucks it hasnt ran for a year but the guy i bought it from says it ran fine when he parked it. he parked it because the ac went out in it. so im trying to figure out what to do with it. im thinking about removing the engine and putting it in my yj. i know i need a new tranny but what else may have to be done to make the engine work. the wiring isnt an issue im and electrician and have factory service manuals for both vehicles. im picking it up tomorrow so i havent even tried to start it yet.
not so stock 89 yj on 35s
bft89yj is offline
post #2 of 3 Old 09-06-2011, 10:26 AM
Que89YJ
You might have the lucky lotto card and got the good axles with it too. Read this:
http://www.jedi.com/obiwan/jeep/d44swap.html
Que89YJ is online now
post #3 of 3 Old 09-06-2011, 10:59 AM
notmyj
This is not a bolt in swap. You will need to get engine mount brackets for a 4.0 YJ. Cut the current brackets off, and relocate and weld in the new brackets for the 4.0. Also, if this is a renix engine I would pass on it, or scrap it to make a couple bucks. Not sure what year the xj got the 4.0HO...
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
anyone swapped early YJ axles into a later YJ???? muddy93 YJ Wrangler Technical Forum 3 01-10-2011 12:02 PM
For those who swapped in a V8..... Grumpy_chef YJ Wrangler Technical Forum 7 05-04-2010 10:47 AM
For those of you that have swapped a 4.0 bamato YJ Wrangler Technical Forum 11 09-10-2007 11:55 AM
I got my 4.0 swapped in... TommyT YJ Wrangler Technical Forum 4 07-14-2007 11:04 PM
Anyone swapped in a GM Gen III V8? Snuffster TJ Wrangler Technical Forum 3 11-28-2005 02:37 PM
