Any ideas on stuck windshield hinges? - JeepForum.com
post #1 of 4 Old 04-05-2010, 09:23 PM Thread Starter
bigjoe27
1987 YJ Wrangler
I have an 87 Wrangler that I am about to Herculine the interior. Then I went to remove the dash to find most of the hinge bolts spin or strip the bolts. I was able to remove about 4 out of all the bolts the ones that are stripped I was going to weld a nut to and try again, but the ones that are spinning is my major question how to deal with. I planned on using a ginder and the welding nuts int the windshield frame but was wondering if anyone has a better idea of A. how to get them out B. how to repair or C. continue with the grinding and welding. Being that the frame doesn't have rust or paint chipping I would prefer to use the frame instead of buying a new one. Also the reason I have to remove the hinges is because they are frozen and PB Blaster did nothing to unstick them so I have new black ones to install. Any suggestions would be helpfull.
bigjoe27 is offline
post #2 of 4 Old 04-05-2010, 09:55 PM
firefighter315
Hinge bolts on the windshield frame thread into threaded plate within the frame and the bolts on the tub side of the hinge fasten with nuts behind the dash. A lot of people will tell you to pull the dash forward a bit to access them, but they can be reached with a little patience and some scratched forearms. Be prepared to work on them blindly and to likely scrape off some rubberized coating to access the threads.
My YJ Build Thread
firefighter315 is offline
post #3 of 4 Old 04-06-2010, 08:33 AM
Brifr1231
if u want to try to free the hinges still i finally got mine free by hiting it side to side with a hammer then using a pipewrench on the round part of the hinge attatched to the windshield, try to rotate it. thats how i got my 89 hinges to work.
MY RIG: 1989 YJ, 4.2l, Black, 4inch Suspension Lift, Bfg ATs around Craigar Soft 8s
-------------------------If it ain't Broke go Break it.--------------------------
Brifr1231 is offline
post #4 of 4 Old 04-07-2010, 07:42 AM Thread Starter
bigjoe27
1987 YJ Wrangler
Nah freeing the hinges isn't the issue anymore replacing them is being that I just decided to manhandle it once so now I have new hinges which were a steal off Ebay I got new in box shipped for 25 dollars black powder coated. So gotta get the old ones off now.
bigjoe27 is offline
YJ Windshield hinges! Jeepguy3401 YJ Wrangler Technical Forum 14 06-18-2013 10:52 AM
Hex bolts for windshield hinges? How do I seal the hinges? ZeroGravity YJ Wrangler Technical Forum 4 05-20-2009 09:34 PM
windshield hinges Jrdicu TJ Wrangler Technical Forum 3 06-27-2007 08:56 AM
Windshield Hinges Qcwrangler YJ Wrangler Technical Forum 12 06-29-2003 07:13 AM
Windshield hinges Jeepguy3401 YJ Wrangler Technical Forum 4 05-17-2002 11:18 AM
