any ideas?.... loud knocking sound! - JeepForum.com
post #1 of 8 Old 02-28-2013, 09:21 PM Thread Starter
njyj609
Hi guys.... have realy enjoyed reading this forum & have learned alot, this is my first post. I recently bought & fell in love with an 89yj... 4 cyl. Ax 5 . I've done a ton of work on it over the last few months & now have a knocking noise which I believe is the tranny or clutch. It knocks (or ticks )while driving and idling. At a stop If I release the clutch pedal enough to engage it slightly the knocking stops.... ??? Performance isn't affected tho, it runs & shifts well .
njyj609 is offline
post #2 of 8 Old 02-28-2013, 11:40 PM
cstone94
Sounds like the throwout bearing inside the bellhousing.
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #3 of 8 Old 03-01-2013, 10:10 PM Thread Starter
njyj609
Thank you.... gonna look thru the Haynes manual& see what it says about the the throwout bearing.... I'm clueless with transmissions..
njyj609 is offline
post #4 of 8 Old 03-02-2013, 04:50 AM
Mark05059
its actually not really part of the transmission although you do need to remove the transmission to fix it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 03-02-2013, 05:21 AM
USMCBuckWild
Depending in the mileage on the clutch, if you are going to change the throwout bearing, just do the clutch at the same time. The throwout bearing is what moves when you push in the clutch pedal. It slides along the trans input shaft and applies pressure to the clutch pressure plate teeth, which disengages the clutch from the flywheel. Typically if 1 of those componenets goes bad; the others aren't far behind.
USMCBuckWild is offline
post #6 of 8 Old 03-03-2013, 08:42 PM Thread Starter
njyj609
Excellent advice& info as usual guys. Thanks much! I am going to order a clutch kit & take a shot at it.... wish me luck...ha
njyj609 is offline
post #7 of 8 Old 03-03-2013, 08:43 PM
cstone94
Come back with any questions. We're here to help!
11' F250 - DD
cstone94 is offline
post #8 of 8 Old 03-03-2013, 09:28 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Welcome to the forum-
Don't forget to post up what you found.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
