Any Ideas? Leaf Spring Pushed Up Against Frame - JeepForum.com
post #1 of 10 Old 08-26-2012, 12:43 PM Thread Starter
goAF
Don't have a cro bar handy or anything to get some leverage. Which might be an awful idea anyway. I jacked it up hoping it'd come down, he put some negative force on it... It seems stuck pretty well. Suspension travel seems maxed like it doesn't want to let it go.
Let me know if there is a smart way to do this. TIA!
goAF is offline
post #2 of 10 Old 08-26-2012, 01:23 PM
sdotcarter
Your leaf is bent. It may be stuck in place now. I'd say use ratchet straps, strap your spring around the frame to hold it. Do the same to the shackle. Then maybe try getting the bolt out or cutting it. The one that holds the leafs to the shackle.
Edit: what the hell did you hit.
sdotcarter is offline
post #3 of 10 Old 08-26-2012, 02:03 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
When you get it figured out, grab yourself a set of boomerang shackles to prevent this from happening again
Luck Favours The Prepared
Anticanman is offline
post #4 of 10 Old 08-26-2012, 02:23 PM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
Had this happen to me a few months ago. I fixed mine with a pry bar and it didnt fling out or anything. Seems like it will but mine didnt. So if you end up finding one or find something similar (hefty shovel IDK) it should come down with some love. BTW my leaf wasn't bent so you might be in luck.
Hoxie is offline
post #5 of 10 Old 08-26-2012, 03:12 PM Thread Starter
goAF
Caught the edge of the river bank pretty hard. Looked softer.
goAF is offline
post #6 of 10 Old 08-26-2012, 03:13 PM Thread Starter
goAF
Thanks for the tips--ill take a hack at it and see what happens. Worst case i just replace em and throw boomerangs on.
goAF is offline
post #7 of 10 Old 08-26-2012, 06:43 PM
FSJMan
throw a chain on it and pull against it is what i did. To solve the problem I bought a set of rockwells and am four linking it. Probably not the best choice to fix this problem but it is an option.
FSJMan is offline
post #8 of 10 Old 08-26-2012, 06:50 PM
Mark05059
jack between the spring and the frame... keep clear cuz when it unloads the pressure its gonna move quick..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #9 of 10 Old 08-26-2012, 06:54 PM Thread Starter
goAF
Managed to eventually get a good pry from the front with a crowbar while i had it jacked up. Popped right back into place, though like some of you mentioned slightly bent. I'm gonna let it flatten out a little go easy on her for a while. Eventually ill get new springs anyway. Thanks for the help
goAF is offline
post #10 of 10 Old 08-26-2012, 07:07 PM
FSJMan
For a quick fix look into something like this may help you out some for not alot of money.
FSJMan is offline
