any ideas for distributor? - Page 2 - JeepForum.com
post #16 of 16 Old 04-18-2010, 12:18 PM
monkeyhouse
Originally Posted by 2uraven View Post
so amoung other things i had oil coming into my carb. while i was changing the plugs i thought now would be a good time to check compression and eliminate the dreaded blow by thought. number five is dead!! 20 pounds is all i got. theres the power issue. by the way the plug gaps were at 45. wtf? throw a used small block in? rebuld? engine was rebuilt 70k ago. not thrilled with it at this point. ideas?
if a teamrush upgrade would be done, it is recommended to run plugs at a .45 gap. Check JeepHammers definitive thread.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
Distributor Cap 97Carter02 TJ Wrangler Technical Forum 4 10-31-2009 10:31 AM
Need help with the distributor jopolly3 YJ Wrangler Technical Forum 4 07-16-2009 10:28 AM
Distributor? sjeep1213 TJ Wrangler Technical Forum 5 03-20-2008 05:56 PM
Distributor cap ? Edward777 TJ Wrangler Technical Forum 3 03-11-2008 07:28 AM
could this be my distributor? coolgreen YJ Wrangler Technical Forum 5 09-24-2006 06:37 AM
