any ideas for distributor? - JeepForum.com
post #1 of 16 Old 04-15-2010, 09:47 PM Thread Starter
2uraven
I think its time to look at replacing my distributor. A cheap fix would be great since I just bought a new coil. any ideas?
2uraven is offline
post #2 of 16 Old 04-15-2010, 09:58 PM
Old4X
1990 CJ7
What is wrong with it right now?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 16 Old 04-15-2010, 10:04 PM Thread Starter
2uraven
i put in a new msd box and it seems like it didnt do anything for me. cant hold in 5th gear and no improvement in mpg. no improvement in power. waste of money? 250k on distributor, 70k on engine.
2uraven is offline
post #4 of 16 Old 04-15-2010, 10:24 PM
Cajun90YJ
Find you an HEI chevy inline 6 distributor from a junkyard swap your gear to it and your good to go as long as emissions are not an issue.
Cajun90YJ is offline
post #5 of 16 Old 04-16-2010, 07:45 AM Thread Starter
2uraven
yea thats kind of the direction i was headed. dont the HEI use a coil on the cap though? I was real excited about my new blaster coil (because it cost more then it should have, not because i thought it was something special)
2uraven is offline
post #6 of 16 Old 04-16-2010, 08:53 AM
Cajun90YJ
some early gm's have an external coil that has 3 (power, tach, and plug wires) running from the remotely mounted coil to the dist. You need a distributor from any 77 chevy or gmc cars or trucks with the inline 6 and plug wires from an 80 ford F-150 with an inline 6. You can reuse the old gear off of your distributor but you might have to do a little grinding on the shoulder of it.
post #7 of 16 Old 04-16-2010, 08:54 AM
TSEJEEPERS
It will not matter what you do to the engine. 5th gear will not be usable untill you regear.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 16 Old 04-16-2010, 01:30 PM
JohndKc
1987 YJ Wrangler
He has a 4.2 on 31's. Mine had no problem holding fifth gear.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #9 of 16 Old 04-16-2010, 01:44 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I am convinced his problem is not related to ignition or coil, I have an MSD blaster coil and 6A ignition (older model) and I can hold fifth gear on the highway with plenty of juice, 31 tires as well... Check your timing and your spark plug gap.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #10 of 16 Old 04-16-2010, 05:08 PM
shatteredsoul
I just went with a reman from the Zone, it is a motorcraft has a lifetime warranty and was about $60 IIRC, my old one was shot.
shatteredsoul is offline
post #11 of 16 Old 04-16-2010, 08:05 PM
Old4X
1990 CJ7
If you have done the Nutter and Team-Rush mods, your ignition system should be able to outperform a stock ignition.
These mods eliminate the computer de-tuning your engine and allow for maximum advance in the usable RPM range. Depending on the engine, as much as 12 degrees of advance (setting with vac advance blocked off for testing) at idle is often possible. This will give you slightly better gas mileage, easier starting, and a more stable idle. Also, off-idle performance will improve. Power at cruise should improve somewhat as well.
Ignition upgrades don't give startling performance gains, more like needed subtle refinements.
Old4X is offline
post #12 of 16 Old 04-16-2010, 10:04 PM Thread Starter
2uraven
The nutter and rush did make a difference for my idle and starting but didnt seem to make any difference in response or on the top end. My timing was already at about 8*. I am not sure how nuttering makes any difference with an new ignition box installed. will start by rechecking my timing and plugs. when i had the engine rebuild i had them install an rv cam. do you suppose that would make a difference in terms of distributor gears if i decide to go with an hei already set up for the 258?
2uraven is offline
post #13 of 16 Old 04-17-2010, 12:14 AM Thread Starter
2uraven
can anybody tell me why when i hooked up my msd ignition i had to hook it up using the white wire AND the magnetic trigger in order for it to run?
2uraven is offline
post #14 of 16 Old 04-17-2010, 08:30 AM
Old4X
1990 CJ7
Can't tell all you have checked, so here are a few more suggestions:
Do the spark plug evaluation by running the engine under load (highway speed) and shutting down. Pull the plugs and read the color to tell if you are correct, rich or lean under that condition.
Pull the advance plate out of your distributor and check if it is the low or high total advance plate. If it is the low plate, you can file the slot and get more total advance when you need it.
Re-time to 12 degrees advance and check for pre-ignition. Adjust the timing down till no more spark knock.
Old4X is offline
post #15 of 16 Old 04-18-2010, 11:57 AM Thread Starter
2uraven
so amoung other things i had oil coming into my carb. while i was changing the plugs i thought now would be a good time to check compression and eliminate the dreaded blow by thought. number five is dead!! 20 pounds is all i got. theres the power issue. by the way the plug gaps were at 45. wtf? throw a used small block in? rebuld? engine was rebuilt 70k ago. not thrilled with it at this point. ideas?
2uraven is offline
Distributor Cap 97Carter02 TJ Wrangler Technical Forum 4 10-31-2009 11:31 AM
Need help with the distributor jopolly3 YJ Wrangler Technical Forum 4 07-16-2009 11:28 AM
Distributor? sjeep1213 TJ Wrangler Technical Forum 5 03-20-2008 06:56 PM
Distributor cap ? Edward777 TJ Wrangler Technical Forum 3 03-11-2008 08:28 AM
could this be my distributor? coolgreen YJ Wrangler Technical Forum 5 09-24-2006 07:37 AM
